2022-03-11
2021-06-26
查看: 9027|回复: 41
[公告] 已经更新为KS 2.2.44 WIN32 & WIN64 多国语言版及材质汉化文件
发表于 2011-2-24 17:39:31 | 显示全部楼层 |阅读模式
0 t/ L5 b; F4 J6 K/ I
: b4 i/ T" l" @/ q% s% B4 A. {2.2.44下载 地址
0 o& s6 R. d! {  {6 D; u% x; \, r- J+ z8 C8 m- f5 }* ~& r$ Y' G
完整安装包:
- @1 ~4 f+ |9 O8 }& {; B3 ]9 h3 G' m1 @
Windows 32bit5 X4 W7 }. j5 k
http://download.keyshot.com/keyshot_w32_2.2.44.exe
+ c/ @/ v" w) [1 i3 x5 ]/ b4 S+ V- `# m# I
Windows64bit
2 T. I* e3 R. K; {http://download.keyshot.com/keyshot_w64_2.2.44.exe
; O- H3 e7 `9 E1 G1 e+ r* q% q$ H6 ~( Q) x  H3 k1 b8 l
Mac OS X* }6 y: ]9 C% ^
http://download.keyshot.com/KeyShot_mac64_2.2.44.pkg
' T6 b  Z, Q6 M# I1 ~6 D& Q" e# x. a# X2 C) r) a. C' O2 e( E, l
0 V* \) z% @  k" }1 I, K
Update - Software only (for existing users KeyShot 2.x users):$ }/ i. q( Y- m7 f/ W
0 s' p8 p8 I7 n* R& x1 J( PWindows 32bit( T8 G) p. z* Q3 ~: Y% R5 F, O1 K. |. x
http://download.keyshot.com/keyshot_w32_2.2.44_update.exe. M6 ?1 g8 I+ F
2 x' _" f; Z, o1 H; q" m: MWindows64bit
1 p# N' A- N- s. m: I1 t! vhttp://download.keyshot.com/keyshot_w64_2.2.44_update.exe
! b6 e( Y2 I9 p0 a' F1 a, M9 a$ E) z4 W
Mac OS X
+ \. l0 I: ]+ d. K* fhttp://download.keyshot.com/KeyShot_mac64_2.2.44_update.pkg6 X  E& C. a: k; k1 `3 L) g
7 n0 x) m, y) g* o
" k0 R: B, i4 x
破解补丁下载:1 O8 b/ A: n2 j. e, N
. U! \( l- u! w$ G1 n8 ]# v4 z5 ~$ Y' X6 P: z" d; e
http://uploadmirrors.com/download/0GZLT0TG/2.2.44.rar
5 T  N. \  \2 D( _*********************************************************************************************************
0 `- h  d- K. `5 j; l由于部分坛友反映用下面的地址进行下载后是2.2.43版
# ^( l$ l% S  H7 i' k/ \目前2.2.43版还没有CK
' }7 V+ e& f: G) v" X2 Y我将2.2.42版上传到了网盘,大家可以到网盘去下载完整安装程序
, F; F+ |% E- A+ P2 {7 {4 W" X  y2 r6 }% ?- d! r
网盘地址$ T8 w* A3 u4 X  X" g( Y5 n" g! y
http://dyn.www.rayfile.com/zh-cn/option/5 W# H8 i3 L; v( Y1 B
5 L. C& v6 X$ s3 p0 J3 e  wKS2.2.42  32位提取码
, I( j4 V% Q" x! h3aa7dc99-40c5-11e0-9eb7-0015c55db73d
' X& Q, G6 L( T- E
4 p3 C, ]0 ?) ~- VKS2.2.42  64位提取码% N' D! }( u4 z' M
562c028c-40c7-11e0-bf16-0015c55db73d1 k3 R: c1 n7 O; k
+ |+ z( L% c8 H$ m8 R; x# d3 Z# P2 ^) w- P+ ?$ x% Y
% X7 S4 W* Y- l8 r4 |7 l
- _  I5 g- A6 N; V  H! I 222.jpg * _6 t# C) u% H' s1 E' c
官方多国语言(简体中文,英语,法语,德语,意大利语,日语,韩语,波兰语)
" P1 O: Y" T3 `, r% k关于Keyshot 2.2更新的内容详情请点这里:http://www.keyshot.com/keyshot/whats_new.html
6 y4 ?: }1 W3 n& q* w**********************************************************************************************9 n0 H( I& Q9 i' T7 H. b# W
之前的 KeyShot 2.2.29 是BETA版,有很多bug。1 y5 Z8 c# |  r& Y, m7 G
后来 2.2.33 中文版推出后,发现有很多汉化上的错误。( l* q3 G( ~' G# R1 U
在5个小时前 KeyShot 2.2.42 版本又放出了下载,这个版本把之前的错误进行了修正+ w; S; e, W4 \% B
******************************************************************************************************& {) i' f5 |( T* P! g& n/ C
2.2.42相对于2.2.33的更新内容如下:1 p9 I, ~$ ?$ \' l* v9 l8 H3 I
我们很自豪地介绍KeyShot 2.2.42。此更新包含这使得它更容易,比以前更快地创建三维CAD模型卓越影像几项改进。
) K- K3 H) S. N2 Q/ {! X7 V0 l# U4 ~( g3 x1 n; @) `- o' ~
KeyShot 2.2包括以下主要改进:) ~8 O. E" }  ]: O; y2 |& ~3 g
% x! [. u# T5 N
' T( i. e6 M& f: ~/ A  g/ Y) z    *保存模型在CAD模型,包括所有层和组件结构
& J& Q9 u, v, L, G1 K" F8 s    *与更快的实时交互复杂的对象: t+ |, C( I8 c* G
    *先进的材料和复杂的设置提供高达15倍的速度/ N: G7 [, I! Z  [( O4 a
    *支持3Dconnexion 3D鼠标
; C* \, f, C& `- x  n    *能够重复的对象直接在KeyShot几何$ b% ^3 w* `) ^  k% Z4 Y& Y
    *进口和出口的材料- w9 {, a' J& U9 j3 @
    *更方便,更强大的发牌
( J+ H& V# X; q3 o* h8 d8 ~
8 ]2 i0 y7 m! ]7 N0 F: j2 x1 ]( A0 U! H* W$ k
+ T0 S! w3 a/ A
    *使用较少的内存,并显着高达50%的速度提高进口商
4 P- R# ]3 m2 u; v; ?    *支持多种新的CAD格式,包括SolidWorks的2011年,CATIA V5的,! E& }1 K- V. Q/ J1 I# p
      FBX的照相机,Autodesk Inventor的AutoCAD和SketchUp中8
, _* V0 v! U) t6 ?+ A" J    *中文,法语,意大利语,韩语,波兰语附加语言支持
0 b' R2 {% r" x( E6 I+ g    *能够保存KeyShot包(。溶度积)的所有几何形状,材料,照明和纹理文件% Y  s( d9 Z' D' ?6 E- M+ ^1 _
& ], j1 F3 D1 \) V9 I( V. h. W7 R
一种全新功能的完整列表可以在这里找到。 KeyShot 2.2是所有现有KeyShot 2客户免费。
5 S- r6 O: g2 F*****************************************************************************************
1 p* A9 c- E8 S( u下载地址* j* I% ~" `! t$ l9 r. U4 S
在KeyShot 2.2中仅需运行“检查更新”(破解版不建议使用)。9 i% n! ~% s( O- ?. A
0 z5 j; A# K8 |/ N
在KeyShot 2.1中使用下面更新安装:& Y4 ~, P: ?: V' [
$ `* f  {8 @6 q# Dwin64: http://download.keyshot.com/keyshot_w64_2.2.42_update.exe- _: Z% l/ g$ ~2 D) g
win32: http://download.keyshot.com/keyshot_w32_2.2.42_update.exe& H) f) H9 n( |  v4 _0 ]' C
mac64: http://download.keyshot.com/KeyShot_mac64_2.2.42_update.pkg
1 O  Y+ o% s8 O7 ^0 y7 \$ G% ?5 a8 S
运行2.0.x或全新安装的,则需完整安装包(建议大家安装完整包):
' W% H# V; E* w6 F, q
; i) U7 V1 Y1 [1 kwin32: http://download.keyshot.com/keyshot_w32_2.2.42.exe
' Z& U. A8 N3 R) N, R4 Q( V( D1 ?win64: http://download.keyshot.com/keyshot_w64_2.2.42.exe/ n* r* x& ^5 E: G) e8 B
mac64: http://download.keyshot.com/KeyShot_mac64_2.2.42.pkg- o* R+ ?9 c( D/ S" R3 c  `3 }
1 ~3 [7 t: \( P% I/ [7 rCK文件32位' d& t( y& u4 e% q
http://u.115.com/file/f482a9583a
2 C. o3 E9 q0 L+ l% w8 A/ \CK文件64位
: p9 B" ?( Z% v& P* Q* \7 n. Lhttp://u.115.com/file/f4c316f525
8 y5 G- L& @' N+ L*******************************************************************************************9 O1 N' Q9 H9 h$ F" _
破解补丁说明:
& m9 y2 L. R) s1、下载并安装keyshot,安装目录注意不能有中文
# {* p2 q3 i0 u9 I1 {9 q4 Y% ]/ J2、解压补丁包,解压前把杀软关了,复制keyshot.exe到安装目录\bin,覆盖原文件,注意做好备份
2 x. v+ h( C( V+ a/ @, u0 w9 t3、运行keygen.exe获取你的lic文件,保存到安装目录\bin中
' u, N1 p0 [$ M! t2 s- a) ]) K4、运行keyshot,点击install license,选择你从第3步中获取的lic文件2 n+ E% K5 v  ^* i; F1 L6 Y
5、完成
& u: n- O% {$ g" V
/ q0 J- L0 @+ J7 N7 s6 d& D) k3 [- t注意:
! B2 r' \* `& q4 T7 X5 F# h1、下载完整版本full install
% B( a" w( T1 T, `3 j! |2、安装路径不能有中文,安装过程中有两个地方
2 z  w( M# J% F/ d' o' j5 _% h3、破解时要把杀毒软件和安全辅助软件暂时关闭6 J* u7 F0 K) U' M* z) e6 C8 A
( ?4 t" P( @# W9 C安装破解完设置为中文界面的方法:
' t/ K. I8 \" Q- REdit→Preferences→User Interface→Language→Chinese→OK→OK→重启Keyshot→完成
: J! @$ F4 W% x; l# u2 Q**********************************************************************************************
+ ^2 r4 Z: C' ^KS2的材质汉化方法,汉化文件见下面的附件6 P2 x, f  {' A1 R8 z
直接复制Materials中文件到KeyShot Resources\Materials 文件夹替换就OK
* q3 e- k1 t0 g0 {7 A
0 k5 H1 O6 ^! g; l# Y; l
  ~8 F  b7 h4 R7 P: h  @! G7 n% V KS2 材质汉化文件.rar (14.3 KB, 下载次数: 100)
发表于 2011-2-24 19:00:34 | 显示全部楼层
任哥好厉害,谢谢了,下载试试。
发表于 2011-2-24 19:38:07 | 显示全部楼层
发表于 2011-2-24 19:54:15 | 显示全部楼层
这个渲染软件确实挺方便的
发表于 2011-2-24 20:41:49 | 显示全部楼层
材质汉化不完全
 楼主| 发表于 2011-2-25 07:30:09 | 显示全部楼层
材质汉化不完全
9 [. q1 {" c! W* E  Z0 cchenlt845 发表于 2011-2-24 20:41 http://www.3dportal.cn/discuz/images/common/back.gif
0 M/ A2 v1 [. F( c" D6 U( e) ]. D  j" a9 @( d4 ?
又碰到一个像你这样的人。哎!
% a) j! w$ c4 Z. _4 D3 x$ S+ A
9 y: }; y8 J( V6 {) L$ N/ p哪里不完全啊?  `% w: @/ Y  S+ Q
没头没尾就来了一句,让大家猜谜那?
发表于 2011-2-25 08:17:43 | 显示全部楼层
不知道可不可以挂在2011版内使用
发表于 2011-2-25 08:41:29 | 显示全部楼层
又碰到一个像你这样的人。哎!
7 H8 O) b& z7 x  I+ v7 H
2 V$ ~- h9 ?- X0 [哪里不完全啊?
& H; _6 h6 v, L) b) Y没头没尾就来了一句,让大家猜谜那?7 k' l& n1 D0 a$ o/ P/ L
任生 发表于 2011-2-25 07:30 http://www.3dportal.cn/discuz/images/common/back.gif
. s5 H6 J$ N$ U( E' e/ ~; b1 K. @要求的人很挑剔啊
发表于 2011-2-25 08:42:22 | 显示全部楼层
昨天发现更新,更新后原来的pj不能用,就又恢复旧版了,没想到今天就来了,呵呵,支持一下
发表于 2011-2-25 09:44:57 | 显示全部楼层
留名!下载过来试试!不怎么用
发表于 2011-2-25 09:51:14 | 显示全部楼层
2.2.42依舊沒辦法通過sw裡面的按鈕直接渲染。。。。。。點了以後依舊什麼都沒有。。。><;4 S8 d4 `/ a2 P4 l
而且選擇材質的時候不定期crash。。。完全沒有2.1穩定。。。
 楼主| 发表于 2011-2-25 10:35:14 | 显示全部楼层
要求的人很挑剔啊
5 s( x' Z+ F2 c$ y阿帕奇 发表于 2011-2-25 08:41 http://www.3dportal.cn/discuz/images/common/back.gif
9 P% H/ q! U; z7 c8 B8 Y$ b
不回答他吧!显得我发帖子有头无尾。* B2 J" m$ `- D, B- [
回答他吧!我还真想不出也猜不出他指的到底是哪里!
9 [! {& {9 f" I" D' T2 I6 Z% A4 c- j3 ?. z% k
在JXCAD论坛的INV版块里,经过了陈伯雄老师几年来反反复复的唠叨和教导,现在那个版块里大多数发帖子提问和跟帖子提问的人都能很好的将事件从头至尾的描述出来,好让别人能更顺利的帮助他。
5 |' x7 v0 A( y1 U5 g4 V9 f
+ L# n! }9 ?7 J# s0 c( O就好比一个人要从北京去上海但不知道怎么走,他心里知道自己要去的地方,路边过来一个人,就上去就问:怎么走?
! H2 f; A; p$ v+ i: h你说被问的人是不是一头雾水!
; h( g! j# T! I5 F; R  M要是过去问:我要从北京 去上海请问怎么走?0 H1 B. m6 E4 j
被问的人如果知道是不是就可以顺利的回答他的问题了。
 楼主| 发表于 2011-2-25 10:37:10 | 显示全部楼层
本帖最后由 任生 于 2011-2-25 10:38 编辑 - V& X1 ]  V, {4 @+ w' M0 P# l
" c8 ?3 r( j2 Q4 ?$ tsihouko 发表于 2011-2-25 09:51 http://www.3dportal.cn/discuz/images/common/back.gif
) ~3 K8 M; @& o. k% S: D' C$ y; u1 S
4 Z) g' z* I: o, Y$ L
我这里也是这样,不能在SW里直接调用KS。我想这和KS对SW的接口文件没有更新有直接的关系。; y, u6 o6 n, D- o5 D6 G
我不常用这个软件,还真没有发现你说的现象。
/ X6 @6 a1 w! _5 q/ C3 u: {如果不好用还可用回以前的版本啊!或者找有效的途径反映给官方。
发表于 2011-2-25 11:05:05 | 显示全部楼层
, n  u. ^; W4 I3 G' p1 \" O) t
3 Q4 U# X  s8 b% m% x& j* ~官方偷偷升級到2.2.43了(文件名和官網都沒有改。。但是安裝後版本號是2.2.43)。。。所有的破解無效~" w+ F0 b" S1 \$ x  z; ]1 _; ]$ J
官方地址的下載已經全部out~5 S3 L) P+ b) j& r
发表于 2011-2-25 11:24:57 | 显示全部楼层
的确没头没尾的,请见谅,楼主第一时间让我们能学习到最新最完善的软件,此份热情,在此诚心感谢。
Doc1.pdf
103.24 KB, 下载次数: 17
发表于 2011-2-25 11:34:55 | 显示全部楼层
12楼,我昨天新建试画了一个正文体是可以直接打开,已保存或复杂的跟装配体没试过,以前的版本是不行
发表于 2011-2-25 11:44:17 | 显示全部楼层
不是不能打開,是調整的時候就會crash掉。。。
发表于 2011-2-25 11:44:42 | 显示全部楼层
感謝分享...學習中....
发表于 2011-2-25 15:19:51 | 显示全部楼层
多语言版包涵中文了,太好了!
发表于 2011-2-25 15:21:44 | 显示全部楼层
破解文件有问题,希望楼主找到2.2.43的破解文件。谢谢!
 楼主| 发表于 2011-2-25 17:41:57 | 显示全部楼层
8 F8 _; c8 ^) F; Mchenlt845 发表于 2011-2-25 11:24 http://www.3dportal.cn/discuz/images/common/back.gif
1 M& i+ [1 D6 x
: r$ i% S) x5 k$ g. F. H
我安装及汉化后,软件自带的材质部分完全汉化了,我自己加入的材质,依然如以前一样。
, [" ]1 h$ s, q# _! K8 l& Z你确定,你的所有材质都是软件自带的?
发表于 2011-2-25 17:46:25 | 显示全部楼层
我是按照上面的方面安装后把KS文件解压复盖的
发表于 2011-2-25 18:11:03 | 显示全部楼层
悲剧,原来用的2.1.5很好,见此处有中文的便喜新厌旧,结果安装失败,总说版本不对。. E3 J/ }3 {& S7 o5 \
我市Win7 64系统+ S/ F3 k8 l0 M: h) T
哪位有高见?!
 楼主| 发表于 2011-2-25 18:27:55 | 显示全部楼层
破解文件有问题,希望楼主找到2.2.43的破解文件。谢谢!% a) g( Y+ s4 P1 z1 I; d/ O" Z
yujinghua 发表于 2011-2-25 15:21 http://www.3dportal.cn/discuz/images/common/back.gif
/ u+ Q* g' P: l8 D& N6 U
2 R/ V( _; `+ q+ k见顶楼最上面的网盘链接。
0 ^% l) y# h$ w- m& T* B新版本的CK有消息我就来更新。
发表于 2011-2-25 20:09:47 | 显示全部楼层
谢谢楼主分享。
