查看: 2238|回复: 3
[分享] 西门子发布Solid Edge ST3的最新补丁MP3
发表于 2011-3-8 08:07:15 | 显示全部楼层 |阅读模式 来自: 中国广东江门
Dear Solid Edge Customer:
+ W8 R: k. ^' l; _+ X2 g$ ^
We are pleased to inform you that Maintenance Pack 3 (MP3) for Solid Edge ST3 is now available for download on the GTAC FTP server.
* Y1 I4 u  T  W  B' X
This Maintenance Pack addresses issues reported by Solid Edge customers. We appreciate your participation in the software support process - - your reporting helps us make Solid Edge more productive for the way you do business.
! i0 _4 U& v$ _1 }1 G
Sincerely,
0 M" W& h2 [$ O" S$ m
The Solid Edge Team
4 p) B5 o# ^2 O0 N' `" k0 ~
( ?+ N+ M/ j& K6 X. C, `% w
Download Location:
( |; U! x* m4 {: A5 V( e
3 }' b- s; d3 [$ k. f
Solid Edge (Maintenance Pack)
" F% D0 D+ c$ k6 U2 s, ]6 _
8 O; V* `; M: W7 M
Solid Edge Insight Connect (Maintenance Pack)
! O+ n: _0 t( _( V0 g* b  N- h
& d% @: M9 J, y! c6 I, r2 ]  X, h
Solid Edge Viewer (Maintenance Pack)
& o. x4 \) r+ H1 `7 P8 R. j) G& J
- ]  G2 _& R( [  {' k
Solid Edge Mold Tooling (Maintenance Pack)
$ {; j3 i( L% L! C1 U  _' ~2 `7 S3 C0 `- a4 n8 E# {5 G
Solid Edge Insight Server WSS 3.0 (Maintenance Pack)
3 ]' Z7 _  \5 L' s
  V8 s& C# l4 ~$ V
Solid Edge Insight Server SharePoint Foundation 2010 (Maintenance Pack)- L# X# a& A# I" s( [1 x" z
http://ftp.ugs.com/solid_edge/ST3/InsightServerSharePointFoundation2010/
8 u7 z" W4 y/ o% Q
Solid Edge Embedded Client (Maintenance Pack)
' F5 H' g6 D" S: W8 C0 G# V4 s
) ^$ ^0 X7 k2 ]( p+ r; ]
Solid Edge Embedded Client Structure Editor (Maintenance Pack)
6 Y' x$ A! f7 O- B8 s, O9 P
5 Z3 X$ T6 ~2 T2 d) t
Solid Edge Embedded Client Administrator (full install)
% K% V. N1 T4 j$ u$ `1 S8 k, G
9 a7 W7 r% m6 `; b& G. O
( f4 ~' V' P/ O; _1 z5 V+ M
Installation:
/ _/ o, R* K2 i8 B& M
7 s/ v" D; M6 Y
After downloading the Maintenance Pack to your machine, unbundle the zip file and then dbl click on exe to install the Maintenance Pack.
9 E" B! W1 R% f/ H: L
Windows 7 Installation tips: In addition to turning off UAC, right click on the exe and select "run as administrator" to complete the installation.
: S0 Q7 ^0 L/ z. i; s5 o- k2 N3 B  k; J
Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing Solid Edge somewhere other than the default “Program Files” folder. Install in a location like c:\SolidEdge\ that the user has full permission to write to.
9 j5 b, b! f& ^% C# n5 u: z
5 _$ b0 a0 ?2 j( I$ I4 `
E-mail Notification:
) h( u. W, t) v/ J$ J- c2 `
: B9 o1 \6 X' p5 O; ]/ M* s- [4 ~
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe to the SFBmail notification. To initiate your subscription, navigate to: http://support.ugs.com/general/email.shtml for the web interface. Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe@ugs.com
" u0 M: z& u" M) @) X
* }6 E) N7 x: J* J+ t* j
This Maintenance Pack addresses the following PRs:
" P% z) A/ N1 f9 v
  L6 C: |' e2 ?/ W* ?
===API===
3 r& H4 X9 B& s; {" x
PR 6426380: Not getting Colors in SEPartReader, SEReader
8 C1 F$ m$ q/ d0 s$ C/ Z) b& [5 t, r
===Assembly===
0 A  f; E4 G* b( D' l, c
PR 1824462: Fixed crashes identified by crashlog files
+ m( g6 _$ h" `  {0 `. O/ s) W
PR 1826468: Path name length is limited to 129 characters in Property Manager
& K% [. H% T# B  n2 V$ T' }
PR 6462576: Solid Edge crashes after selecting part of SysLib after placing it
( `# d$ D9 Q  u) g# G: J$ s$ Z6 N, W
PR 6465652: Abort if save is clicked while config file open dialog is active
/ m2 F1 @2 c# c4 n0 p6 \0 l
PR 1829176: Unable to activate zones with double-click
  o$ |9 ]3 ^% z2 G0 O
PR 6471148: Display performance is slow on rotations and zooming
) v. @- `, m! `8 p
PR 6474039: Fixed crashes identified by crashlog files
4 w) ^2 D; [3 x) N1 x5 ]% `
PR 1815765: Unable to open Catia V5 R20 part files
! F6 R& q: J7 O0 B8 s
PR 1828742: Solid Edge Frame Design / Routing API.
/ ?- W7 q* e" a  j: f
PR 6417945: the default location of the Quickbar / Assembly Pathfinder is not correct in Sketch
3 y$ B7 J, V+ X3 _8 U! v
PR 6429834: Patterned frame members list is on separate line item in Parts List
; p) P- p, K# t& O# x
PR 6461646: scroll to part results being obscured by the relation tree
  k+ Q! N% w8 ^7 q1 J) n
PR 6470893: Solid Edge is slow to open a Parasolid assembly
# z% k2 y0 t, Z. x& d
PR 1819591: Assembly aborts when creating relationships
- s* _3 q6 m) [, J" d7 y
PR 6469074: Assembly reports are not picking up custom property values
8 m0 @4 F' p, q. T
PR 6472642:  New Menu Starting Wrong Template
+ _0 `3 z* U- N. n) z
===Draft===
3 P1 ]$ W$ C" {) E, G6 ~. P: {
PR 6327121: Abort on close if dim tracker has been run and something remained in the select set
$ o* n, W: k& z
PR 6357213: Callout Text gets merged if Alignment is changed to Center or Right
4 L" B5 C- g% g( Q2 G& ~) W
PR 6412216: Dimensions detach on update
0 s' W. i2 M3 Y% T
PR 6427966: Part aborts revolving a synchronous cutout
" x7 ]% y  F5 B4 X, o
PR 6429679: Exiting profile causes an abort
8 `9 v& L) F4 ^" m# E2 j
PR 6454096: Cannot exit edit boundary environment after ctrl-drag of 2d object
4 x/ g0 t5 X7 \' V& I. x# R' f7 G
PR 6456030: Solid Edge open DWG Options/Review are not giving the correct sheet information
& ?# g. o* R9 R7 a' B" C# R6 ^
PR 6456838: Can't place a dimension in a Detail View using dimension axis
4 o1 @2 C3 k. t$ y" G9 H
PR 6464949: Parts list moves up and left by .175 mm when opened
, K7 _5 U9 W5 J* {
PR 1816750: Cannot select elliptical arcs in hole table command
  a) m* n( n5 j$ v8 d# }
PR 2162210: "Thread Display Mode" changes value when Apply button is clicked on other property pages
  H' Q& H7 Z  u) ?" n2 z) Y
===Insight/View & Markup===
7 [) W7 e) @# Z* `* o0 F& x  [% I
PR 6457292: Failed to generate document libraries property mapping information
; R. H; r1 [4 q1 @# {! H
PR 6465929: Insight server log files cannot be generated for SharePoint 2010
* Y( h  R" g* `7 O" C: M9 w& ?
PR 6466137: Registry key VMOnSaveEmbedViewingLink not delivered in ST 3
& H  x1 Q  H* _0 m8 S9 P
===Part/Profile/Sheet Metal===
7 t  X7 u$ R7 ^+ g
PR 1776878: Callout for %HS is incorrect on Part Copies
* G* F$ b; F; I8 T$ m+ I& [* F4 g
PR 1824462: a crash that may occur when imprinting curves
# t- h/ b. c- O( \! L
PR 6367518: If Relationship Colors is on, no indication when dimensions are failed
1 U# v; N8 @; o
PR 6434556: a crash occurring when locating items in pathfinder after closing a file
" E5 G' e% y  }; c3 o
PR 6453116: Immediately after rotate you see a flash of the model in a different orientation
* h0 E, d5 }4 N6 I1 Z1 ~* Z7 G
PR 6456053: Sync Hole gets deleted if it’s used sketch is deleted after a Move to Sync
! P( @9 _. q3 ]; p/ M4 ?* E% p3 W
PR 6467561: the Solid Edge process hangs around after selecting a region then exiting
. h! A8 O( q( V: l0 |  q+ d3 [
PR 6468272: Unable to edit a dimension value with a key-in after scrolling with mouse wheel
4 k/ ]$ y- y: u+ l: C
PR 1809044: a crash is occurring when trying to open a Solid Edge file
' v6 z, a  P4 G: c
PR 6471224: the concentric live rules turning red when using local symmetry option
4 `( ~, r6 L% m6 \6 x- a
PR 6471336: Dimension display disappears during edit formula
% H/ L( q  S- C- z$ C
PR 6473059: sync move appearing sluggish on keypoint locate
! s+ m' `' H8 v3 q% @( Z& [" N
PR 6474371: Cannot pattern a hem
' T  @9 k$ u- p) {, k- `- N9 K9 m
PR 6475818: Send Mail & Crashlog tracking failing under Lotus Notes
- y' z, Q0 a3 [0 i6 a. N5 S
PR 1827775: Displaying the FOP table takes a long time
* _0 P4 |2 h& O% w, J
PR 2163514: "Show Only Overridden Variables" of the family of parts not being displayed
% c7 }8 F/ U2 |6 L; Y3 F
PR 6477746: Cylinder from a Lofted Flange in ordered sheet metal part has incorrect flat result
发表于 2011-3-8 08:32:11 | 显示全部楼层 来自: 中国北京
不明白别的补丁和Solid Edge (Maintenance Pack)http://ftp.ugs.com/solid_edge/ST3/SolidEdge/
# }* s7 @9 @) d' ?
! \" Z/ J: v# M( T7 ]这个补丁是啥关系?
发表于 2011-3-8 12:47:42 | 显示全部楼层 来自: 中国辽宁鞍山
比较关心升级了mp3后,原来的破解还能用不了
发表于 2011-3-8 12:53:55 | 显示全部楼层 来自: 中国北京
9 b9 H) g7 f, e; i- b7 `) o0 d308408 发表于 2011-3-8 12:47 http://www.3dportal.cn/discuz/images/common/back.gif
: L3 W; Y" R1 C# G: S
可以用
