2022-03-11
2021-06-26
查看: 3928|回复: 12
[分享] 亲爱的Solid Edge的客户: Solid Edge ST3 MP4现在在GTAC FTP服务器下载。
发表于 2011-4-23 13:26:30 | 显示全部楼层 |阅读模式
Dear Solid Edge Customer: We are pleased to inform you that Maintenance Pack 4 (MP4) for Solid Edge ST3 is now available for download on the GTAC FTP server.
$ c2 c1 Q. q8 A: F1 ]( O% q4 C  ========== ) j( c7 D  m. M& r
Installation:
) ?' L8 f' N0 V( P: v$ t6 R==========
! c9 O2 x" ^1 c* X5 j! T After downloading the Maintenance Pack to your machine, unbundle the zip file and then dbl click on exe to install the Maintenance Pack.3 o% b  A. s. L; O  U; [
Windows 7 Installation tips: In addition to turning off UAC, right click on the exe and select "run as administrator" to complete the installation. 3 g8 M9 m9 g, j$ `$ k9 Y( Q6 u
Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing Solid Edge somewhere other than the default “Program Files” folder. Install in a location like c:\SolidEdge\ that the user has full permission to write to.
5 M% J: q2 n$ U, N" P0 G& ~4 G  R===============
; K& X) I, ^0 R0 c5 lE-mail Notification:
" i2 r8 l6 I$ A" w( D; n. G7 z9 h===============3 T7 ?# a9 p1 p, X' C
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe to the SFBmail notification. To initiate your subscription, navigate to: http://support.ugs.com/general/email.shtml for the web interface. Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe@ugs.com 2 ^6 `& d. a; B
5 _1 o# v& Z$ gThis Maintenance Pack addresses the following PRs:0 {9 v6 D/ B& y# _
=========================================1 n" K* r  W& q9 H) U8 G& T" s( \
===Assembly===
& D( c" H2 G' d- Y" m3 pPR 1833635: Web Publisher result are incorrect if a part has sync and ordered features
8 a5 ^. P# Q7 vPR 1832106: Copied sketch elements, linked to the parent sketch, can be modified or deleted& L, o& k* I. b' ~) }" q
PR 1835705: A crash occurs when a section view is applied and a part is placed5 C, P( I$ |7 ~7 [* o
PR 2161686: Path dimensions disappearing in the frame environment.- b$ j! p+ r5 W
PR 2163832: Assembly pathfinder losing display of icons and hide/show boxes; ?8 E6 x: @2 _
PR 2164176: Crash in XpresRoute when placing dimensions- K2 D$ W3 Y) |; |0 z( w( l
PR 6426117: Fails to create Chamfer on Frame Pattern occurrence in first attempt
4 U8 b& ~  C, \* C1 m( ZPR 6446233: Mirror assembly command fails with error message
- w! V0 n& e; ^0 P9 bPR 6459239: No user defined properties in assembly query
" \% {) Y' m: H3 p! }4 k: _PR 6463932: Face of the flange should coincide with the endpoint of the line4 n8 F% g9 c; }; Z" v9 e" c; G
PR 6471354: SAT file fails to import all bodies% y: T% [' e8 [& f  U: J4 Y; s
PR 6484211: mass of frame components incorrect
# I8 g; N, Q! Y  K4 |% ~PR 6382855: Change Source button is disabled in the Edit Links command
9 Y* B* M# Y. X2 {* ePR 6427250: pathfinder needs a lot of scroll in a particular workflow
2 [0 P6 n' y! b  ^PR 6472286: smart installer does not provide a way to not update already generated parts
  j- P7 U6 Z# ~7 NPR 6450569: Crash on Right Click in Configuration Manager
' L2 k+ o2 K" {PR 1823993: Offset value field disappears if more than one part is selected2 c2 E+ M$ f5 E' h/ w
PR 1834121: Unable to open X_T file in ST3
& A0 W5 r: o) l" a3 nPR 1837775: Solid Edge hangs when selecting a link in pathfinder8 v7 h4 z- z8 x1 t7 U3 v
PR 1840226: Cannot enter an offset distance of zero
; P" g5 W* z) C* sPR 2164215: Unable to create spur gear as done in ST20 \% i6 P4 ]1 Y+ F( R7 d
PR 6469288: 'Apply Configuration' dialog comes up, when applying subassembly configuration 8 c( h+ x8 E! w6 Q) M
PR 1838609: 'Center Distance Between' missing in Synchronous Pulley Designer
# @! s6 {! \) m$ D+ GPR 6447436: the Select Identical Parts command not being available in ERA/ H( ^  S& I! q3 p. v; A9 l8 b/ Z
===Draft===
  n  ]0 }! b/ p+ A: r9 |4 U/ T9 bPR 1827819: Property-text "Mass" (in draft) is empty, if drawing is opened without model+ n" {1 D- n  F' p
PR 1831283: Texture Symbols and Geo not imported5 J3 N$ ^/ v3 {4 d0 L. R- ?
PR 1836610: Unable to save a single sheet to PDF to its correct size
) N2 x5 {0 Q$ D. ^# mPR 2097195: The space of the tolerance is too large& @! s% T4 D2 u6 e0 v
PR 6438504: Retrieve Dimensions will only work from one model at a time2 E9 y  o$ E4 @' i
PR 1830981: Parts list header text wrapping changed V20 vs. ST3# Y& \3 p: S! h: R
PR 1833476: Copy link / Paste special does not give correct result in ST3: s$ i) n1 j6 P* K* X
PR 1836176: Draft where SE crashes in connection with 3D Device and mouse drag( d+ F' u9 l. a( p3 _. W0 O
PR 1836241: Parts list is not showing FOA member names* b+ k" i: ^7 g8 k. ^. P0 p
PR 1837622: Cannot open or create drawings after installing ST3 MP34 |' M4 e. K! b6 G" i6 J4 ~
PR 6476574: sheet being renamed7 f& w" e( `6 n) t; R2 Z
PR 1840034: Performance problem updating views with PMI model views specified
8 ]4 j" j9 ?  v7 }7 Z% mPR 6439408: Bad Display in PDF 3 {# u3 R: h0 i  Q/ k! d# V) @( C
PR 6495446: Predefined Draft Text (Annotation) Alignment does not work/ M, V: {  E+ _) b7 Q' s1 R
PR 1840906: SE aborts when updating view
' i$ h, W: Y1 K- o1 @8 UPR 2166384: Leader display has changed from st2 to st3
( n- X; {9 |( B) B$ l$ s/ k! rPR 6461898: %RT does not work like it did in ST2' d3 T% k8 D, l' j1 F& ~
PR 6491943: Drawing view properties section tab not enabled/disabled based on PMI view selected
+ f: b5 s4 S1 a8 M+ R===Insight/View & Markup===% X( I4 Q% ~& Q8 a8 \+ _  Y
PR 6483466: Search not returning results from top level site only sub sites
  y* m+ S4 ^; d0 F, c& a4 |PR 6484521: Crash saving as pdf into a DocLib with required properties1 {/ R/ ?+ U; r* s2 u* _1 O) W
PR 6497333: Errors in Insight Logs since upgrading to MOSS2007/ST30 i6 l) A1 Y! D/ _3 E
PR 6483575: FOA property mapping problems with SharePoint
/ N$ K. Z$ L  j+ x2 f ===Part/Profile/Sheet Metal===
7 ?+ v3 H1 r3 |; \3 G, ePR 1834162: Draft option in synchronous extrusion doesn’t work properly
* P6 x9 p6 _7 m" i- ]& M, OPR 1824904: "Show only" is missing in ST3 ordered
0 R/ P! \  B0 x0 G; P5 j  C* ^& tPR 1832775: close corner reacts different in ST2
9 I$ z# E# F- F, E0 kPR 1833282: Sheet metal local symmetry doesn’t work (Live Rules)2 g" i+ H* a0 Y8 @. L
PR 6493372: Bend direction not showing on printed .psm documents from batch mode
) X7 l, W! O2 a! }% Y1 v/ Y* JPR 1835549: Unable to pattern a feature
! R9 X+ [* T+ E; S8 n8 P2 Z1 ZPR 2164158: Extrude created a feature with a duplicate name4 @, `) x( H/ H6 K# Y
PR 6489351: Crash occurred while reorienting the steering wheel while in SE Simulation
3 {  a! n5 X0 U2 _0 A9 bPR 1838826: Dimensions placed with feature are not editable in FOP
# N+ B& l( t0 E' zPR 2165475: Japanese command tips being garbled in crashlogf.txt; @" n+ _$ f( u: P9 L! M  S
PR 6493558: User is unable to scale a part copy when importing it into a new file, m# }* V( n* q3 h' _
PR 1826580: It’s not possible to assign part material with ordered and synchronous features8 O3 ?3 _; s( @8 ~. |1 b: {& [
PR 1829378: Material Thickness on Gage tab of File Properties dialog is no longer accessible9 S5 f9 p. W; ~% Y, Q6 q
PR 1833358: feature library is not working* Y) H: ?6 O7 y
PR 1837948: Unable to flatten a psm file
  G% I& I3 O9 rPR 1838687: Solid Edge aborts when populating FOP members
% ?/ o, w1 z+ S: E0 QPR 2165291: Normal Distance causes an abort in Japanese ST3 - Sync* p/ X' \3 v; o
PR 6385655: radial edits taking too long for synchronous models6 S4 ~  r. `, N& G
PR 6389400: Wrong result on flat of conic shape with cutout& b$ r! r, M6 Y- ^. ]
PR 6442323: cutout in ST3 synch part that takes 10-30 times as long as ordered
5 v1 i$ y* q, V+ P  s9 pPR 1704478: After dissolving UDS, features don't remain selected* p- C' z  L8 v( J% g2 x  e" B0 X
PR 1816608: smart pattern performance - applies to both pattern and pattern along curve8 t8 z& E1 t/ W- t; o" J
PR 1838985: Countersink is lost when re-bending
% a) }% k; L) ~PR 2166692: Unable to select curve control points for connects with Solid Edge x64+ [( }/ S( f6 E2 n& Y% c: k1 O
PR 6461572: Pattern Plane creation is incorrect most of the time
9 J& [" \; [7 I* P- nPR 6469130: Product uses a lot of memory when placing sync cutout using Text Profile4 d) s( ?6 [) O* [% d
PR 6509580: edit handle arrow does not point to edit face
+ ^3 T6 y; ~* V- F- o  p ===Solid Edge Embedded Client===
- G* D) V1 p$ U1 wPR 6479486: SEEC API OnGetWhereUsedForAutomation does not work% m. `% C. ~9 n! }8 t/ u
PR 6495362: Unable to Check-in documents; returning document has moved or is missing error2 L$ W( L9 O7 p; J& ]2 t
PR 6507472: Need to verify the back port Item Number - Find No. Integration project- s. x7 M: u/ g9 r* Y) T
PR 6484387: No warning given for Item id conflicts with virtual components
2 x: Z" L3 k8 v7 l# P9 R7 Q% qPR 6512292: Next Available Number command doesn't consider TCVC
  e8 y7 f4 j6 f9 _( fPR 6441245: Modified weldment feature is not updated in structure manager in RAC
4 h* ], t9 [3 c8 K! t* iPR 6471911: SEEC does not recognize multiple revisions during open in an assembly
$ [2 G+ G8 d1 U' aPR 6482868: With PS_new_seqno_mode=none the Occurrence Properties show nothing
7 V  R1 F- Z9 O, ^% B/ nPR 6512110: after deleting assembly feature the JT is not updated in the Tc viewer
发表于 2011-4-23 18:11:51 | 显示全部楼层
Solid Edge ST3 MP4 update on local FTP/ P% d( @; l3 t1 p& O
http://www.3dportal.cn/discuz/viewthread.php?tid=1030829
参与人数 1三维币 +20 收起 理由
msyanzi + 20 好资料,感谢您对论坛的支持!
发表于 2011-4-23 18:25:56 | 显示全部楼层
本帖最后由 368天 于 2011-4-23 18:31 编辑 * `9 R2 @4 J+ {# Z6 m4 \" ?9 m
* R& H6 m* _; u; N5 M
已经更新。破解还是以前的那个吧?
发表于 2011-4-23 19:26:09 | 显示全部楼层
已经更新。破解还是以前的那个吧?. _3 O. }! w0 |; K- B
368天 发表于 2011-4-23 18:25 http://www.3dportal.cn/discuz/images/common/back.gif
% U9 O. u" a& vthe license is the same one as I shared befor for SE ST3 MP1  J7 Z  w4 }, k
* Z" Q- J2 V1 R3 ?With this lisense files are not blocked for SE ST2 MP12 (and lower) and SE ST3 MP4 (and lower)
发表于 2011-4-24 18:34:52 | 显示全部楼层
这个是什么作用  谁能解释下吗   对破解版ST3有没有影响
发表于 2011-4-24 20:48:01 | 显示全部楼层
% E6 r' l+ U( ywyheag 发表于 2011-4-24 18:34 http://www.3dportal.cn/discuz/images/common/back.gif
+ b3 _" s; P, W8 Q$ `0 O
官方补丁包
发表于 2011-4-25 11:36:30 | 显示全部楼层
谁能上传到电驴或者网盘啊,这些地方分享的人才多
发表于 2011-4-25 14:06:43 | 显示全部楼层
发我邮箱里,谢谢。
 楼主| 发表于 2011-4-25 16:34:11 | 显示全部楼层
8# huanghao1987 # N/ C$ G' u  ^
9 Y/ O% @) I* H$ ]6 O这不有一个新的免费下载地址吗,自己不仔细看。哈哈。
  S3 h0 U2 @/ D: U) W+ T+ y  [% a! u. H( U1 `
http://www.3dportal.cn/discuz/viewthread.php?tid=1030974&extra=page%3D1
发表于 2011-4-26 10:33:25 | 显示全部楼层
还是希望官方能说明,修补了哪些BUG,也好让用户们清楚是否应该及时升级。
 楼主| 发表于 2011-4-26 18:36:19 | 显示全部楼层
这帖子的内容就是说明啊。可惜只是英文的。看不看的懂看大家的造化了。
发表于 2013-6-18 17:36:02 | 显示全部楼层
多谢,请教怎么下载,新人啊
. c* X. U$ n% V; u  g# d
发表于 2013-6-19 06:00:21 | 显示全部楼层
) v  F5 |0 E: J3 ~) O4 f
感谢楼主共享
