Dear Solid Edge Customer: We are pleased to inform you that Maintenance Pack 4 (MP4) for Solid Edge ST3 is now available for download on the GTAC FTP server.
' D$ \! V+ O9 v; G ==========
; R- ?7 W8 p( Z9 g8 L9 b; uInstallation:. s3 h. x% _9 M9 M% K
0 f0 R: l$ t/ l' B* _# H T& ` After downloading the Maintenance Pack to your machine, unbundle the zip file and then dbl click on exe to install the Maintenance Pack.
/ E& o# d4 _& r: V# a Windows 7 Installation tips: In addition to turning off UAC, right click on the exe and select "run as administrator" to complete the installation.
; d2 j8 O p; X4 K/ ^. f; n: | Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing Solid Edge somewhere other than the default “Program Files” folder. Install in a location like c:\SolidEdge\ that the user has full permission to write to. / h7 x& Z5 F: m* T3 P+ I( V2 i8 ~
( z ~; W5 I; t. dE-mail Notification:
+ G5 [8 P2 p; W- q% T===============0 \8 g) h/ E# L4 g5 j
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe to the SFBmail notification. To initiate your subscription, navigate to: http://support.ugs.com/general/email.shtml for the web interface. Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe@ugs.com 4 J. P% o, O8 v4 E6 {
=========================================1 @3 d3 i8 p9 `- V/ n3 K' ^4 F2 T
This Maintenance Pack addresses the following PRs:3 |( F$ q- D+ Y
=========================================9 K! n& h) |+ ?5 \$ B( c( c2 |$ `/ q
===Assembly=== - p. }/ @. O+ I) P! @ D; i4 [
PR 1833635: Web Publisher result are incorrect if a part has sync and ordered features0 i7 k! V* [9 x. ~# Z, p$ T
PR 1832106: Copied sketch elements, linked to the parent sketch, can be modified or deleted* b$ F1 O3 X2 S
PR 1835705: A crash occurs when a section view is applied and a part is placed
1 o3 G3 P; b- X: u5 m7 K3 VPR 2161686: Path dimensions disappearing in the frame environment.
. p8 h$ X2 }% d: {$ o0 LPR 2163832: Assembly pathfinder losing display of icons and hide/show boxes
4 u! r* f1 D8 M/ \4 CPR 2164176: Crash in XpresRoute when placing dimensions
* o+ X: M9 @/ i8 }# YPR 6426117: Fails to create Chamfer on Frame Pattern occurrence in first attempt
3 }( X4 p7 z' `" _7 U6 s7 {PR 6446233: Mirror assembly command fails with error message
J$ K* Y0 C8 ?- `' Z& `# g0 wPR 6459239: No user defined properties in assembly query$ ?3 a. R9 k" Q6 K/ p1 o/ k
PR 6463932: Face of the flange should coincide with the endpoint of the line8 P. N6 y- ~* d* c/ Y
PR 6471354: SAT file fails to import all bodies2 N( I8 |% Y% _2 F5 ?3 Z
PR 6484211: mass of frame components incorrect- l- [# C$ T8 L9 s/ e
PR 6382855: Change Source button is disabled in the Edit Links command8 U0 N) `- u! l9 w$ p) @
PR 6427250: pathfinder needs a lot of scroll in a particular workflow9 s* Q3 |7 y' W
PR 6472286: smart installer does not provide a way to not update already generated parts
3 ~2 h% m5 _/ T- c9 O5 \- GPR 6450569: Crash on Right Click in Configuration Manager7 _- w( L* ~9 E- L# H
PR 1823993: Offset value field disappears if more than one part is selected
' ?: l- J$ s- r$ s5 JPR 1834121: Unable to open X_T file in ST39 H' c8 c3 o" p) g
PR 1837775: Solid Edge hangs when selecting a link in pathfinder
x; Q4 {( I2 k+ H/ RPR 1840226: Cannot enter an offset distance of zero4 Q/ r5 A. j }, s
PR 2164215: Unable to create spur gear as done in ST2
|# _; d; ~ j8 o) rPR 6469288: 'Apply Configuration' dialog comes up, when applying subassembly configuration
) G( b1 o5 n: i# u/ LPR 1838609: 'Center Distance Between' missing in Synchronous Pulley Designer- c2 o, k; @" [! k
PR 6447436: the Select Identical Parts command not being available in ERA
7 i6 o. E- B/ P# ~) g! S1 ^# n8 D& G- n===Draft===
# d5 u+ ^9 R* U9 r' t! J; iPR 1827819: Property-text "Mass" (in draft) is empty, if drawing is opened without model9 K+ v( [, f* T0 L
PR 1831283: Texture Symbols and Geo not imported
+ f* ]7 L& Q9 m4 _9 ?( {PR 1836610: Unable to save a single sheet to PDF to its correct size+ Z; _9 i! K; ]8 U9 e
PR 2097195: The space of the tolerance is too large
5 I; R9 V; p5 e/ h+ gPR 6438504: Retrieve Dimensions will only work from one model at a time7 l( x- o: A# v
PR 1830981: Parts list header text wrapping changed V20 vs. ST3/ x7 N& j/ F7 E# F) l! z3 i# a4 n# T
PR 1833476: Copy link / Paste special does not give correct result in ST3! c( v' z* Z7 S0 [4 G
PR 1836176: Draft where SE crashes in connection with 3D Device and mouse drag1 N# Q! ~; {2 g! h/ R& T
PR 1836241: Parts list is not showing FOA member names6 B9 A$ J# e: o# \# [8 y1 @
PR 1837622: Cannot open or create drawings after installing ST3 MP33 l2 C) Q W& _! m1 s9 X; u
PR 6476574: sheet being renamed
7 v9 H1 z0 ]% H# OPR 1840034: Performance problem updating views with PMI model views specified
% B- y2 X6 V+ D& DPR 6439408: Bad Display in PDF
# G! q0 v$ g; [; Z0 CPR 6495446: Predefined Draft Text (Annotation) Alignment does not work
: K1 H) a2 n: BPR 1840906: SE aborts when updating view' o) Q3 Y0 D2 Q+ g- u
PR 2166384: Leader display has changed from st2 to st3
% r7 k* l; w+ mPR 6461898: %RT does not work like it did in ST2
% U1 k* r3 Y& M+ f' KPR 6491943: Drawing view properties section tab not enabled/disabled based on PMI view selected. c H, E( e4 U* w1 v; k3 z U6 @& V7 T
===Insight/View & Markup===/ m7 L, b0 N5 X2 T% b
PR 6483466: Search not returning results from top level site only sub sites
6 ~" T. V. x; U. Q5 wPR 6484521: Crash saving as pdf into a DocLib with required properties, Q' `# ]: E; j7 b0 |" ^
PR 6497333: Errors in Insight Logs since upgrading to MOSS2007/ST3
" W9 f, d) A0 b8 BPR 6483575: FOA property mapping problems with SharePoint3 M2 ]. z3 x) N5 I7 w7 H
===Part/Profile/Sheet Metal===
7 a6 {# u; D8 ~$ J5 b Z: |/ m9 oPR 1834162: Draft option in synchronous extrusion doesn’t work properly7 h* x4 [# k8 C1 q4 w* { P0 n
PR 1824904: "Show only" is missing in ST3 ordered' p2 D! J5 b. J. z" T' ~, Q0 }
PR 1832775: close corner reacts different in ST29 t% S* ^7 T9 V' V. d
PR 1833282: Sheet metal local symmetry doesn’t work (Live Rules)* F0 v s* s3 v5 ?0 ~8 s
PR 6493372: Bend direction not showing on printed .psm documents from batch mode2 K/ i9 f" m' _- T0 p0 K1 ~ h8 Y
PR 1835549: Unable to pattern a feature
- D, w' i2 B5 fPR 2164158: Extrude created a feature with a duplicate name
7 u7 `% ^! U. u: T' m: J9 E2 u( kPR 6489351: Crash occurred while reorienting the steering wheel while in SE Simulation0 w5 c* G; R- Q
PR 1838826: Dimensions placed with feature are not editable in FOP
2 Q. ?" C6 D, e( I& l* DPR 2165475: Japanese command tips being garbled in crashlogf.txt4 j: e+ U( F2 G( J" T
PR 6493558: User is unable to scale a part copy when importing it into a new file
' F/ u0 C5 Z2 N g6 P+ h+ QPR 1826580: It’s not possible to assign part material with ordered and synchronous features m# o$ C9 B9 S1 A% `* k& y
PR 1829378: Material Thickness on Gage tab of File Properties dialog is no longer accessible
7 E6 ^( |+ M: R0 O/ |4 GPR 1833358: feature library is not working/ ]0 ?! q7 ` Y. j8 P4 s( y, p8 ?
PR 1837948: Unable to flatten a psm file
$ \& b g; [" D' ]/ `PR 1838687: Solid Edge aborts when populating FOP members
" k: A& Y% o( SPR 2165291: Normal Distance causes an abort in Japanese ST3 - Sync
+ H" G9 L- y0 B" h+ X8 i9 DPR 6385655: radial edits taking too long for synchronous models! c7 T" e7 \' b J) S8 o
PR 6389400: Wrong result on flat of conic shape with cutout
" O1 _$ Q6 H/ J: I& w) Q$ o1 u( cPR 6442323: cutout in ST3 synch part that takes 10-30 times as long as ordered
: B% Z. e/ g$ A$ o: W2 } W! j, cPR 1704478: After dissolving UDS, features don't remain selected' K4 j; M. `# }1 x- p% k
PR 1816608: smart pattern performance - applies to both pattern and pattern along curve
" N6 @; @) P$ q x3 nPR 1838985: Countersink is lost when re-bending
- k* s( A# H! G& o$ d6 u( wPR 2166692: Unable to select curve control points for connects with Solid Edge x64
6 Y9 U5 c( a/ }/ q7 u/ QPR 6461572: Pattern Plane creation is incorrect most of the time
% W2 S1 S C& A, x# B" x+ mPR 6469130: Product uses a lot of memory when placing sync cutout using Text Profile
3 y3 X$ V( c m; y. zPR 6509580: edit handle arrow does not point to edit face
* y1 t; y, a! e7 n ===Solid Edge Embedded Client===: p) f" E- _$ d5 w, H& ~
PR 6479486: SEEC API OnGetWhereUsedForAutomation does not work0 j- _( F9 t) W0 F- s; ?
PR 6495362: Unable to Check-in documents; returning document has moved or is missing error
) O* a: f+ _% Y7 d8 PPR 6507472: Need to verify the back port Item Number - Find No. Integration project
3 I% P- D) j* S9 P: j; b2 LPR 6484387: No warning given for Item id conflicts with virtual components ! c# c; L+ y/ `8 a. u0 [4 [
PR 6512292: Next Available Number command doesn't consider TCVC
0 S4 }' T2 ]3 @- {$ Z/ CPR 6441245: Modified weldment feature is not updated in structure manager in RAC
; _6 B& G. F) l+ P0 nPR 6471911: SEEC does not recognize multiple revisions during open in an assembly
6 O; v* | J0 C3 Q/ |PR 6482868: With PS_new_seqno_mode=none the Occurrence Properties show nothing
' }! Y) c6 G" f( {& m, r1 c s( a( VPR 6512110: after deleting assembly feature the JT is not updated in the Tc viewer |
