Dear Solid Edge Customer: We are pleased to inform you that Maintenance Pack 4 (MP4) for Solid Edge ST3 is now available for download on the GTAC FTP server. - d3 O& i/ _( n0 r# `: a
8 d) B" G/ k2 r, uInstallation:
# N6 V7 t2 _6 ?. c: o==========) S* d8 C0 n0 r( l5 _
After downloading the Maintenance Pack to your machine, unbundle the zip file and then dbl click on exe to install the Maintenance Pack.* {8 E' U* @) Z
Windows 7 Installation tips: In addition to turning off UAC, right click on the exe and select "run as administrator" to complete the installation. * A+ Z& h4 T2 H8 S; G
Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing Solid Edge somewhere other than the default “Program Files” folder. Install in a location like c:\SolidEdge\ that the user has full permission to write to.
, q" ^0 @& M% T0 }# J===============
* \* C: T& J9 q8 p( ?" y- u5 l3 `E-mail Notification: + w, ?& `1 m- V7 x
=============== a0 r0 u) N) h; k
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe to the SFBmail notification. To initiate your subscription, navigate to: http://support.ugs.com/general/email.shtml for the web interface. Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe@ugs.com
4 Y" s% A1 `! z' l =========================================7 |* v; f( }& X) h. p, ^
This Maintenance Pack addresses the following PRs:; Q. ^7 d6 g# e" W
=========================================. A0 k& ~3 P0 ?6 u% h- U
===Assembly=== 3 a0 M; n. F5 y- }* c7 Y
PR 1833635: Web Publisher result are incorrect if a part has sync and ordered features' J$ {8 m m l# N) ]# _) N
PR 1832106: Copied sketch elements, linked to the parent sketch, can be modified or deleted
9 R1 j" ?* P9 m! e D" }* iPR 1835705: A crash occurs when a section view is applied and a part is placed4 a) s5 l" C0 f/ K
PR 2161686: Path dimensions disappearing in the frame environment.# E4 L' T' p/ p' p# k
PR 2163832: Assembly pathfinder losing display of icons and hide/show boxes
" y) P. w& O5 b' iPR 2164176: Crash in XpresRoute when placing dimensions$ K# k' x% _) _
PR 6426117: Fails to create Chamfer on Frame Pattern occurrence in first attempt
9 i* n# v% Z* c0 n {; nPR 6446233: Mirror assembly command fails with error message7 `3 F6 c$ H( Y, w
PR 6459239: No user defined properties in assembly query
- J# `) a- B% ?8 Z$ f8 g, x9 uPR 6463932: Face of the flange should coincide with the endpoint of the line
; l/ U# Q+ w( V; {5 Y. R5 m: w: a7 j5 cPR 6471354: SAT file fails to import all bodies
3 A! U. r8 j$ r. m1 {; LPR 6484211: mass of frame components incorrect
, L7 J! e8 X( R" i [( y& ^" \ pPR 6382855: Change Source button is disabled in the Edit Links command- M: v9 o! N: O( G1 J8 l) s- r
PR 6427250: pathfinder needs a lot of scroll in a particular workflow/ H5 ^1 m% Y D' A) x
PR 6472286: smart installer does not provide a way to not update already generated parts
' H9 K: G' Y( Z# m SPR 6450569: Crash on Right Click in Configuration Manager; M! x7 V# w6 y0 S( G
PR 1823993: Offset value field disappears if more than one part is selected
; G5 b8 d# X3 J9 [* Q" e/ p! ?PR 1834121: Unable to open X_T file in ST3' V$ ^4 \' R# O3 L1 F/ ]* {
PR 1837775: Solid Edge hangs when selecting a link in pathfinder! N# |1 ?" Y$ G) a( l/ Q
PR 1840226: Cannot enter an offset distance of zero
' z/ ^0 r" o4 V5 qPR 2164215: Unable to create spur gear as done in ST25 a& q% v- |% T% i `
PR 6469288: 'Apply Configuration' dialog comes up, when applying subassembly configuration
4 z; h. ?; P8 c e+ v3 E/ kPR 1838609: 'Center Distance Between' missing in Synchronous Pulley Designer
. Q) e0 G3 v) ]' h" ]+ BPR 6447436: the Select Identical Parts command not being available in ERA" D6 i- [# Z/ Q3 z: E R
===Draft===
/ }- c2 X, y i0 P% `2 tPR 1827819: Property-text "Mass" (in draft) is empty, if drawing is opened without model
2 C: K. L( X% K5 J/ N6 SPR 1831283: Texture Symbols and Geo not imported
) i$ h5 [; I) e9 R: VPR 1836610: Unable to save a single sheet to PDF to its correct size
0 C9 H, t3 X3 q1 m# H3 APR 2097195: The space of the tolerance is too large
! R) P$ {6 @& O: v! f5 oPR 6438504: Retrieve Dimensions will only work from one model at a time
, ^9 C" i: K) GPR 1830981: Parts list header text wrapping changed V20 vs. ST3% I$ ?) j7 R: m0 O4 B& N/ E: @
PR 1833476: Copy link / Paste special does not give correct result in ST3
% v8 o. C; L5 j w& WPR 1836176: Draft where SE crashes in connection with 3D Device and mouse drag
- z |5 h7 h( f3 NPR 1836241: Parts list is not showing FOA member names5 E; |8 J; ]" f+ O
PR 1837622: Cannot open or create drawings after installing ST3 MP34 p) I0 P c' H% x7 w- G
PR 6476574: sheet being renamed1 d. f1 @, \3 D3 ~
PR 1840034: Performance problem updating views with PMI model views specified
( k7 X/ m* D5 Q$ tPR 6439408: Bad Display in PDF 6 m+ I* n5 C0 W& L( \& y4 m
PR 6495446: Predefined Draft Text (Annotation) Alignment does not work
/ ^, S7 i# P: IPR 1840906: SE aborts when updating view& ~' Q/ R4 B; |' d9 Y
PR 2166384: Leader display has changed from st2 to st3
7 G$ t. w4 @) E+ zPR 6461898: %RT does not work like it did in ST2
4 W8 Y0 {4 P* I' a% t' pPR 6491943: Drawing view properties section tab not enabled/disabled based on PMI view selected
4 G% r# V/ H$ a( X===Insight/View & Markup===; ]8 a3 A- G8 |* D$ j* H
PR 6483466: Search not returning results from top level site only sub sites
$ s6 k; n3 K o' R OPR 6484521: Crash saving as pdf into a DocLib with required properties
! ?" _: U+ C1 aPR 6497333: Errors in Insight Logs since upgrading to MOSS2007/ST38 E6 Q5 `; M! A, \
PR 6483575: FOA property mapping problems with SharePoint
' g( ^; }3 m' d, W, c ===Part/Profile/Sheet Metal===
: ?& v' Q3 Q9 g* O2 FPR 1834162: Draft option in synchronous extrusion doesn’t work properly3 u5 A4 j/ ?5 w% e' `
PR 1824904: "Show only" is missing in ST3 ordered
9 r# }" \) ~$ x8 \; O; \0 ?PR 1832775: close corner reacts different in ST2 F& @8 r5 j/ T. u3 `8 x3 [
PR 1833282: Sheet metal local symmetry doesn’t work (Live Rules)8 }/ [2 l7 F) _
PR 6493372: Bend direction not showing on printed .psm documents from batch mode
. _0 }2 Y3 r& n. D$ UPR 1835549: Unable to pattern a feature 1 W, t( M- P7 |- p
PR 2164158: Extrude created a feature with a duplicate name
* Q1 D5 F/ n4 r3 `PR 6489351: Crash occurred while reorienting the steering wheel while in SE Simulation
l6 R0 X" `2 e; ^PR 1838826: Dimensions placed with feature are not editable in FOP
0 A* b. {$ m2 w( h+ h7 U) o* IPR 2165475: Japanese command tips being garbled in crashlogf.txt
9 J5 r9 ~' J1 y' U; V1 T8 fPR 6493558: User is unable to scale a part copy when importing it into a new file
% M+ l9 l( x, k1 e0 a2 c. [PR 1826580: It’s not possible to assign part material with ordered and synchronous features
! p/ }" x) y% x* d, I$ mPR 1829378: Material Thickness on Gage tab of File Properties dialog is no longer accessible0 k" V1 d% d7 C T
PR 1833358: feature library is not working
- F7 Y6 r k9 A/ g" aPR 1837948: Unable to flatten a psm file " w7 e. \ w4 f U1 E6 d" m
PR 1838687: Solid Edge aborts when populating FOP members# \: m6 B/ b) q5 F- S
PR 2165291: Normal Distance causes an abort in Japanese ST3 - Sync
0 U5 Y9 P* D& uPR 6385655: radial edits taking too long for synchronous models
+ P) ^* }0 m2 OPR 6389400: Wrong result on flat of conic shape with cutout
8 I9 p j$ k7 v5 w! y1 i* oPR 6442323: cutout in ST3 synch part that takes 10-30 times as long as ordered
0 Y/ W/ V' [; q8 g: RPR 1704478: After dissolving UDS, features don't remain selected+ H$ R; R: n% b
PR 1816608: smart pattern performance - applies to both pattern and pattern along curve
8 ?; c$ K" f# cPR 1838985: Countersink is lost when re-bending @5 ?# ~3 V# C' R
PR 2166692: Unable to select curve control points for connects with Solid Edge x643 ?) v9 E: L8 M- J* E) X
PR 6461572: Pattern Plane creation is incorrect most of the time
- E! N8 z; ^- I; i, K r) u1 a" mPR 6469130: Product uses a lot of memory when placing sync cutout using Text Profile
* F/ w8 m5 p$ z% j0 Y" f% h# q+ ePR 6509580: edit handle arrow does not point to edit face. c! s6 m4 @- z: J
===Solid Edge Embedded Client===
; X9 r; l9 s( r& `& [PR 6479486: SEEC API OnGetWhereUsedForAutomation does not work8 q& I0 l* R+ U `
PR 6495362: Unable to Check-in documents; returning document has moved or is missing error
/ Y6 d8 \& s" Y) B, |- IPR 6507472: Need to verify the back port Item Number - Find No. Integration project
2 T- [, m8 V9 S+ c9 S. y, {* _! fPR 6484387: No warning given for Item id conflicts with virtual components 3 r, U) L! Q- U9 }! [5 {' L
PR 6512292: Next Available Number command doesn't consider TCVC
/ u! A" w1 {* g( u+ ?PR 6441245: Modified weldment feature is not updated in structure manager in RAC
$ W$ V# a0 b/ |5 t6 U+ K8 ^" CPR 6471911: SEEC does not recognize multiple revisions during open in an assembly
+ e9 Z/ v+ r7 ]- ~: FPR 6482868: With PS_new_seqno_mode=none the Occurrence Properties show nothing
9 T; Q" e' V5 ZPR 6512110: after deleting assembly feature the JT is not updated in the Tc viewer |
