2022-03-11
2021-06-26
查看: 2779|回复: 13
[已解决] 请问下这个程序出什么问题了
发表于 2011-5-21 21:43:17 | 显示全部楼层 |阅读模式
: N: V  ]) y" W# |  j/ Y
: k% ~( u3 S8 p" o7 @& H' m5 m0 |程序怎么出来是一条直线呢?书本也是这样的,谢谢各位指点一下
  1. (defun C:15()
    : x* |2 N, F3 L1 o0 k4 M
  2. (setq pa (getpoint "请输入三角形左下的点:"
      F# i$ {8 W/ K! H% D) d
  3. (setq ww (getreal "\n 输入底边长度:"
      |7 F5 y% {- t! w5 t
  4. (setq kk (getreal "\n 输入斜边长度:"
    3 v  _# F0 c4 Q; X3 I
  5. (setq pb (polar pa 0 ww))
    3 J8 H4 n9 w5 r0 v- S
  6. (setq hh (sqrt (- (* kk kk) (* ww ww))))
    ; ~' Q- W/ {3 j# w
  7. , r/ V  |; o, H# y0 K  I$ ?
  8. (command "pline" pa pb pc "c"0 d* m, A5 |8 h. |  Y$ h
  9. (princ "\n 另一边hh的长度=" (princ hh)8 b4 O% C, G8 r3 l) Y
  10. (setq ang_pb (atan (/ hh ww)))
    " ]" E' W" i8 O( n( \
  11. (setq ang_pb (* atan_pb (/ 180 pi))) 0 A  `" W5 h2 s- r' l! J
  12. (setq ang_pc (- 90 ang_pb))
    6 Y3 C4 H- s7 |0 v
  13. (princ "\n pb的夹角="
    & V2 d; m- a8 ^" }# y
  14. (princ ang-pb) 1 F5 j6 v1 S. N4 M( z! M
  15. (princ "度"+ j; C3 P* o; Q8 W# M
  16. (princ "\n pc的夹角=" 9 c, R$ Y2 C+ ?4 s2 V! [0 B6 A# s
  17. (princ ang-pc)
    9 w- ?5 I, G# s  m
  18. (princ "度"/ B( x8 Y6 \& b
  19. )
    9 ~2 j. I" D* g1 }3 T5 h
  20. (prompt "\n 自动完成 "
    : P. C1 V+ h+ }
  21. (prin1)
    1 e4 ]7 U% W8 _) M
复制代码
发表于 2011-5-21 22:26:43 | 显示全部楼层
(setq ang_pb (* atan_pb (/ 180 pi)))0 C0 U0 x/ N+ C! A  D
(princ ang-pb): H4 m- N( D) ?8 o& z% F
(princ ang-pc)
7 [# D4 I; p5 j2 L* I: R
==============/ M9 ^% }, B& f5 Y
  1. ' W# u% h& m' y- Z2 [
  2. (defun C:15 (). q$ t( O; i1 ~  g) a! A. \: c, }, D# l
  3.   (setq pa (getpoint "请输入三角形左下的点:"))
    5 T$ w1 J3 _0 ]: J
  4.   (setq ww (getreal "\n 输入底边长度:"))
      a9 n. A" F6 e: x/ g$ e
  5.   (setq kk (getreal "\n 输入斜边长度:"))6 I: ^$ X$ w% H9 k4 B/ J# s+ X0 o
  6.   (setq pb (polar pa 0 ww)), H$ x7 O$ o5 }: r$ T" u3 A
  7.   (setq hh (sqrt (- (* kk kk) (* ww ww))))
    . M/ L* H) R$ i3 a! _: ~
  8.   (setq pc (polar pa (/ pi 2) hh))
      l: J6 k+ S% S# ~2 t
  9.   & F! k  q( \$ H. ^9 v1 d
  10.   ;; (setvar "OsMode" 0)  ;捕捉
    % f+ d+ g  g& T$ d; I9 D) W
  11.   (command "pline" pa pb pc "c")
    9 c: \6 G1 v+ @4 C$ F( i
  12.   (princ "\n 另一边hh的长度=")
    2 T. o. k. ~# y# J) f' U0 N
  13.   (princ hh)1 L% I- i$ Y# Q- x! y
  14.   (setq ang_pb (atan (/ hh ww)))- J2 M# u4 G) ^
  15.   (setq ang_pb (* ang_pb (/ 180 pi)))/ t/ q" W( _% I
  16.   (setq ang_pc (- 90 ang_pb))* f# W% L) F' f0 B( {
  17.   (princ "\n pb的夹角=")
    ' ^5 j  x/ e5 I: _+ p
  18.   (princ ang_pb)  (princ "度")
    / \5 e8 H4 ]( t7 l  h
  19.   (princ "\n pc的夹角=")  (princ ang_pc)$ l" p7 k& b* u8 P/ P4 T+ p
  20.   (princ "度")+ D: K3 c( B! |$ g1 O
  21. )& x8 g. Y# d: m
  22. (prompt "\n 自动完成 "). P+ B8 @$ b" b0 ]/ v
  23. (prin1)
    4 G6 h$ C- x+ U
复制代码
woaishuijia + 5 应助
 楼主| 发表于 2011-5-22 14:24:01 | 显示全部楼层
2# SunVei " H6 K  y/ F; M" g* |
谢谢啦,确实可行啊,麻烦可以指点下出现什么问题了么?
发表于 2011-5-22 14:50:56 | 显示全部楼层
請比對您的代碼....
& ~) n3 |7 ]# }xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
6 h8 t- o- M) f/ W" l(setq ang_pb (* atan_pb (/ 180 pi)))  u9 U' J- n; f: V) a4 e' L
(princ ang-pb)8 I  U) j' `* a, o6 O
(princ ang-pc)
5 c5 l5 J8 C9 ]
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx4 C$ G  z& k3 R6 L) Z6 I  a1 B5 D
1 J& m1 _3 y' S1 }0 v
/ J- [! a$ S6 Y* o3 a: j1 R
发表于 2011-5-22 18:06:25 | 显示全部楼层
缺少第7行(计算pc的那一行)
 楼主| 发表于 2011-5-22 20:35:25 | 显示全部楼层
5# woaishuijia
7 i% S- x0 c+ t. V
. u; B  N0 ^: `# |9 d- x呃。太粗心了,谢谢两位高人啦。
 楼主| 发表于 2011-5-22 23:53:16 | 显示全部楼层
5# woaishuijia 2 n  O( m' A: w. Y2 q
再弱弱的问一下,怎么最后的一行有两个“度”的呢?. ^( A. Q3 ]$ i
pb的夹角=41.4096度
# V) w% Y. ~0 @: Q. O# ? pc的夹角=48.5904度"度"
发表于 2011-5-23 02:55:58 | 显示全部楼层
按lisp的规矩,函数运行结束后会显示函数的返回值,也就是最后的结果.具体到这个例程,就是最后一行(princ "度")的结果:显示一个字符"度"9 q4 {% P( i7 b0 o
在自定义函数的最后一个右括号之前添加一行(princ),函数的返回值就成为空值了,就不会有多余的显示.
  1. (defun C:15 ()- z* }0 P2 |( W7 f( R0 `  V
  2.   (setq pa (getpoint "请输入三角形左下的点:"))
    5 @0 V. p) {/ N$ L; C' W+ N+ n
  3.   (setq ww (getreal "\n 输入底边长度:"))
    ( V, W$ Y* v5 h3 q
  4.   (setq kk (getreal "\n 输入斜边长度:"))' H7 L+ `/ L8 {9 \7 y& v% g
    + E1 ]9 n& ]* c( c
  6.   (setq hh (sqrt (- (* kk kk) (* ww ww))))0 p/ L9 F+ Z: N1 \
  7.   (setq pc (polar pa (/ pi 2) hh))# ~( @" [2 V3 L* X& ]$ O1 T; t
  8.   , v' O1 |( M9 Q1 W1 s! N
  9.   ;; (setvar "OsMode" 0)  ;捕捉
    1 y6 m# T& H; Y, O
  10.   (command "pline" pa pb pc "c")) Q0 w* Z/ l2 J2 i7 O0 V6 N
  11.   (princ "\n 另一边hh的长度=")
    0 r% S. }# d9 H+ L
  12.   (princ hh)
    3 a/ V7 c, q7 t
  13.   (setq ang_pb (atan (/ hh ww)))( h, j) D7 I9 K  l/ L, K
  14.   (setq ang_pb (* ang_pb (/ 180 pi))); \( n* K% c; t  _+ q8 H6 y5 {
  15.   (setq ang_pc (- 90 ang_pb))
    : |3 Z; X7 L9 r- ?' ?, v4 Q1 o
  16.   (princ "\n pb的夹角=")7 T; w3 y1 c3 u3 R' }1 j4 _
  17.   (princ ang_pb)  (princ "度")6 y( u; x' _5 u1 R- _8 H9 I  d- V
  18.   (princ "\n pc的夹角=")  (princ ang_pc)
    8 f; {' \: A0 e+ ^: E: _
  19.   (princ "度")9 V' ~, W5 c9 G" |& s5 q
  20.   (princ)
    3 R( \. Q- ]/ v0 E+ T7 Y1 n9 m, [% I
  21. )+ f7 |$ g  r" M
    0 b4 G" O+ m5 o6 K
  23. (prin1)
复制代码
 楼主| 发表于 2011-5-23 07:31:56 | 显示全部楼层
8# woaishuijia ' f8 i* c7 `) O" Q( }. m0 z" L5 W
都这么晚了,版主不睡啊,辛苦了,问题解决
 楼主| 发表于 2011-5-27 13:19:34 | 显示全部楼层
2# SunVei   + d( B+ Z1 I8 `  [! C) F3 n% u
;; (setvar "OsMode" 0)  ;捕捉$ @+ X* Y% I& O6 ~
请问下一开始的两个分号起什么作用呢?应该可以去掉吧?
发表于 2011-5-27 13:49:56 | 显示全部楼层
Lisp ....." X$ T- K8 _. y( l
列首见 ; ---> 跳过这一列1 d1 q8 ]4 [' K4 F$ e/ X
) R: j7 p" O" m( c本例 暂不关闭捕捉+ e5 r0 G  X0 }4 l
实务上建议 关闭捕捉
 楼主| 发表于 2011-5-27 14:05:50 | 显示全部楼层
11# SunVei
8 y. l% N# |* M- E! u那请问有没有方法可以临时关闭捕捉呢,就是在这个程序运行的时候关闭,如果运行后就恢复?
发表于 2011-5-27 14:11:18 | 显示全部楼层
现成的参考
" ~5 L1 a5 _: j, e0 _( K0 dhttp://www.google.com/search?as_ ... +%E6%90%9C%E5%B0%8B
 楼主| 发表于 2011-5-27 16:49:23 | 显示全部楼层
本帖最后由 janekou 于 2011-5-27 16:52 编辑 + @) j9 q, K) z: D5 M6 B
* P: _( q# d) L' v3 a; O看了后,还是有点不懂,请问两个分号也是注释?
! s" j$ t8 M# ^7 r" z8 Q; d) X) F# s而那个703  (setvar "osmode" 703)是什么意思呢?(如果是0的话应该就是取消全部捕捉了吧)$ k; S* }" S& f% L( e
还有是怎么设置只临时捕捉的呢?
  1. (defun c:an (/ aa la lb lc sz area lh bb ah ang1 cc )     ;将命令定义为an
    ( s0 Y5 G9 e2 T
  2. * i$ K* z5 S/ X5 @
  3. (setq Osnapmode (getvar "OSMODE")                       ;获得当前捕捉模式
    ) d/ D. Y6 }. o3 @
  4. (setvar "OSMODE" 703 )                                    ;设置程序中需要的模式% f. L8 M( x9 _- I- ^6 S- }, S- j
  5.      9 f% a0 U8 u  o
  6.           : V$ A1 J; @* r
  7. (setq aa (getpoint "选取左下角点:")  L# Y, [+ B  S; J, L
  8. (setq la (getreal "\n 输入底边A的长度:")
    9 f" V/ _; @2 p
  9. (setq lb (getreal "\n 输入B的长度:"); B1 i4 S' s7 H( F8 U! Y; @0 E
  10. (setq lc (getreal "\n 输入C的长度:")7 a3 Z3 {* h+ ~3 ~9 h" C
  11. ;貌似下面的叫海伦公式, c6 @( p# l; `2 f
  12. (setq sz (/ (+ la lb lc) 2))
    - a* b4 L, l  i+ R: w# `! y, H
  13. (setq area (sqrt (* sz (- sz la) (- sz lb) (- sz lc))))* G0 ^9 w+ L  ~! z
  14. (setq lh (/ (* 2 area) la))
    & ]! ^7 B0 {6 k  r* J
  15. 0 ^  ?# j) K  z; ^: ]# Y
  16. (setq bb (polar aa 0 la))
    . K' c) g* B) w* ?7 A) c3 q; P
  17. (setq ah  (sqrt (- (* lc lc) (* lh lh))))
    ; N) l- P# a" b+ m) }% x/ H: n
  18. (setq ang1 (atan (/ lh ah)))       ;ang1弧度值
    $ h& }, j* v! Q: I
  19. (setq cc (polar aa ang1 lc))
    % s& D: h" g; x* s- X' m" c
  20. (command "pline" aa bb cc "c"
    8 \1 A( Q) {( ?: i( C6 E
  21. ;显示相关信息,可省略
    + i0 A  J: T3 p' e, r1 R" ^
  22. (setq ang1 (* ang1 (/ 180 pi)))    ;ang1弧度值转换为十进制角度值
    ) B0 z! e: i0 U
  23. (princ (strcat "底角度数=" (rtos ang1) "度"): y$ W7 ^7 C" @# ~: @4 j( t
  24. ;上一步或者可用(princ "底角度数=" (princ ang1) (princ "度"
    4 i, h: x3 l9 }, I3 {
  25. & y! L7 L3 ^4 H8 Y
  26. (setvar "OSMODE" Osnapmode)                                ;恢复初始状态
    4 Z& O$ g; W. K8 k
  27. $ ~& I1 v* Y2 x4 x$ a8 v
  28. (prin1)4 H4 T6 J9 v5 Z9 A; e) R
  29. )
    1 d5 U4 y1 T7 O+ G
  30. (prompt "哈哈,入门级的水平啊,见笑了"+ J) f( N* }& G1 Z% V
  31. (prin1)
复制代码
貌似这样插入有问题~~
