楼主 |
发表于 2011-12-5 19:34:23
, G$ M% f1 m& h( } c
2 q @0 E. _7 P3 o0 u5 g0 B' a
List of fixed bugs
/ T. C4 l7 p& Z -------------- + ~1 P& H: O- H7 h7 S" T
Release Notes:
( L8 L1 u& {. @9 J' _8 `-------------- ) Z# Q7 B; N! l) b( _) R
3 a0 m, i+ p, Z2 j4 U, D+ C/ ]" @
Product: Solid Edge
' e" z+ |. Q. ^- V; ~& u! N9 `5 KVersion: 104.00.02.05
! a+ p* F4 V1 \Date: 17-Nov-2011
, h& q7 w& m* g, t" ^2 y-------------------------------------------------- 8 o3 R' r- ?: s; E4 f& w/ u( ?
This Maintenance Pack addresses the following PRs: 4 d1 t9 t. d/ w8 e
! A% C9 J) w n! E8 h8 x
6 N, n$ s. s) g1 s, G9 C7 ~===API===
+ a9 n% }' [; h0 d+ C
J+ M# |' y y k" ^PR 1858168: Problem with the Add-in Menu, does not display correct the first time, works fine the second time
% W$ t9 r' b- S' R
' ^$ o( X! e3 D& P( j===Assembly=== * L- K8 p+ K: e4 m( N
( `3 e$ E/ J' t( f3 M& ~6 t/ ~PR 1863648: Drag & Drop performance depends of asm size and if components are hidden or not
4 e# e+ m! z$ }' C; p9 K4 D1 E$ S; S8 HPR 1867394: Wrong result if 'Ignore interference between matching threads' is activated
R# K0 Y: z5 q/ X: N5 v) `' ?PR 6555905: Parts Library tab is slow to open when an Insight .par or .psm is last selected/highlighted in the tab # D( B z) K2 w& o9 s
PR 6584857: Assembly hole features not honoring number of holes in profile - w( C7 p1 w3 L1 I
PR 1867986: Unable to delete button when macro not found , f5 Y2 s2 f. D) u' l
3 l6 P3 {7 A9 u( f===Draft=== 9 [. }+ C/ N0 ~! M
5 o' P0 `8 z2 O5 J: C/ b' ePR 6579864: Having problems selecting a Pipe in Draft document 6 |8 V3 k# \& [0 H: J/ Z" E
PR 1867983: Parts List column Property Text is changing when ST2 file is opened in ST3 or 4 / e, y7 S9 P/ }
PR 6603842: Parts List maximum row setting is overwritten
$ @- b& E" o4 d0 EPR 1868919: Diameter symbol in callout displayed as %DI in 3D pdf
1 P" _ M# {0 ?' |& H5 XPR 1869690: No options when saving .emf in draft environment
0 Z6 W" f$ [1 _& E( v4 _PR 6541132: Cannot Open NX8 Documents 8 T2 y- y) Y0 Z- |* t
PR 6599967: Solid Edge crash # M U& Z% v* `
PR 1869499: Moments of inertia will not consider the scale Factor
# G2 U6 t& h% Y; R/ {PR 1870486: Line up text with left alignment does not work properly / b) A1 K* K3 i; I, u' V7 b
PR 6609433: Crash when placing drawing view after hitting back button in DV wizard 9 m h7 e. [$ N8 @
PR 1826842: Parts list is not exported when attribute layer mapping is on 0 J" S3 c6 e# h/ @
PR 1842000: There is a gap between leader and break line of a callout in certain positions ( S2 K0 x! h7 _* R8 M, S* ?8 k
" k$ o" L' I; o* m
===Part/Profile/Sheet Metal=== 1 t; d5 x2 a7 U0 s) H
- @; B9 I3 I/ ~0 I+ Z
PR 1864164: Sheetmetal files contain incomplete property structures in the Material Data 5 I& M- K. [! y- s# C$ J5 ]0 R
PR 1869122: Automatic detection of add/remove wrong in this case
" q2 H9 S6 [; f9 g% p# CPR 1869195: add/ cut option automatically switches to add when selecting axis of revolution
0 |8 {* @- c# Z1 G8 O: _' EPR 6599667: reduce time for processing result in Simulation 0 q( O. o G6 ?0 Y( v' y# I
PR 6603049: Cannot enter value and units while in the Move command in ST4 * N1 K2 x) S" {# o
PR 1862713: Holes with threads cannot be selected for adding relationships
! E2 L% L2 e; ~+ |! CPR 1867683: Rigid does not work for hole features - r7 ?. _2 c: [ |. u$ ?8 d0 q& K
PR 6583151: Property overrides (simulation) is not taken into account
( m5 i) ~$ C( e, _9 k
! P U" T+ E3 c9 U4 e===Solid Edge Embedded Client===
; n! R/ p/ M% |% U; @) y
1 {/ Z4 I: V; b1 f1 cPR 6420435: SEEC Problem with graphic display in Teamcenter Feature Library tab # n3 G5 R1 C l" l' P8 L6 O
; K/ O9 s4 P1 M! d6 I' K
* F* n: L2 ]) ^* Q1 YEnd
4 x: d Z8 D& c! E: q--- |
