发表于 2012-4-25 22:11:59
这是最详细的安装I-DEAS 6.2 m0 说明" s) J1 F; x- _
仅供参考
& G0 _$ g0 }$ Y2 iNX I-DEAS V6.2 M0 INSTALLATION( J! N) _9 d! w+ X. N( ]' Z
1, in control panel delete all of these selected items:, h9 w- H/ a, i% h8 `
a, I-DEAS NX series9 n: ^$ r7 Y- p2 l
b,I-DEAS Resource locking service
: b) K. J) ~8 T2 U* Z3 g8 rc,I-DEAS SFAM component, P) j9 R4 Q8 ~& p/ K
d,Java 2 SDK,SE V1.4.2_053 e' w* v2 D* F) h* m
e,orbix4 |4 @& I- u V
2,restart your computer5 C, V2 w, N1 S( O" Y5 b( E
3,Nothing related I-DEAS and java left
% T1 Y0 m( J) C9 Q: [5 i0 { D0 A4,delete I-DEAS related files in windows registry, use run “regedit”: K9 H) v; l/ h; w9 U5 ?
5,begin to install I-DEAS V6.2 M0' I5 _) L$ T( o; B
6,Do not install UGS license server
/ u9 U! [: }- @1 e ]7,install i-deas nx prerquisites6 O8 K+ b# i' O R0 o, K2 L5 t
Notice:1),change the path to what you want,remember ,Chinese path not permitted.(you”d better choose the default).. Q/ X# Y, S/ y8 W; c
2),if you can not install this step, you maybe reset the windows system.if your OS is the Windows 7 (64bit&32bit),you must hold the right mouse, you required the administrator permissions before you run the programs..
* p& ?- S: J; o( s. N- }5 t7 D7 z8,we continue to install environment after computer is restarted.
3 _. ~# p2 f0 c' R9,install the i-deas nx serices setup.# S9 A } a8 `% A1 H( Q/ ?; C
9.1 install shield wizard’s dialog box comes out in design product group select this 4 items(A004 Assembly set,you can choose the all if you need)..
+ K/ x0 |( a9 R5 GSelect the language your OS used,if you are using an English OS,don”t need to seletct anything.(you can select the Chinese simplified and Chinese traditional.
: O* x' |+ k+ _9.2 in license server’s dialog you need change the local host to your computer name.5 L# w0 ~9 A& X i# S/ v
10, accept all the default items and finish the installment.
8 X4 q& N$ E" m11,install help if you need it
! [/ P! k( M* V12,exit setup% C+ O- j* W" N; t+ {/ z
13, replace orginal …\lic\nxlic.dll with cracked one. Copy “nxlic.dll” to folder I-DEAS 6.2 prog dir\lic (by default c:\siemens\nxi62\lic)and overwrite orginal one.
9 X, V3 T& X8 \2 d14,before running i-deas run”TDI Wizard” and install i-deas resource locking service.(continue to configure the team date.)
: b2 R/ ]2 v: v) {Open TDI for mainmeau:
3 s; @2 ~2 N/ b, \7 \Create and publish a teamdate installation
% ?; ` o7 B" J; F8 PSet the team master ID:1/2/3/4 more than 1% A z2 ?! S, w! _! b
Next you can default set,finish all the default option,
/ V. I* m r3 q7 p; S& m# t2 _15,enjoy.6 F3 N' ^1 j5 p4 i7 o; E
Notice:that’all. No flexlm server or license are need.: G- y/ H% O3 n8 A( L) x' u4 w
+ R* s* ^& ]/ y `; u$ `& n安装中最容易出现问题,建议重装系统后再安装。
6 Z. \$ F l1 S, S2 r1 U# F无法开启界面,最主要的是NX I-DEAS resource locking service 没有开启,可以在控制面板 管理工具 服务中查看,可以手动开启
- y% `; @ T9 c1 v, B安装前确保磁盘文件中不包含中文。
7 P3 E, y! ~5 J! A5 z启动时可以右键通过管理员权限设置i-deas在起始位置中指定默认存放文件夹,默认为空白。
5 t7 w( ]; ^' \/ E6 P2 H新建文件名不能包括中文及数字。 |
