8天前
查看: 4612|回复: 1
[分享] 涂料通用术语英汉
发表于 2008-2-28 00:43:37 | 显示全部楼层 |阅读模式 来自: 中国福建漳州
通用术语 " @2 b' H7 b: B8 B4 [5 L; H; p; l
, a) k. V; e# p$ n! u
涂料 coating 7 X  g/ G/ D) y7 @1 t* T% A& J' m
有机涂料 organic coating
: N+ _" ?: r7 N# l  S. j# \( D7 E' @无机涂料 inorganic coating1 v: v; c' j8 P! ?3 R; _6 ?
色漆 paint) g; u  g, Q% p$ L
厚漆 paste paint
: W4 b" V3 f% a9 o调合漆 ready-mixed paint  o8 f: _/ N1 C. {) V
磁漆;瓷漆 enamel
. s' c3 c0 L  m1 b2 a# d# M3 E腻子 putty;filler# W2 v" `; y4 j. j
底漆 primer
$ C8 p2 M2 q- }/ r二道底漆;二道漆 surfacer2 ?, R! m8 l3 z" \, j) c  w6 n
面漆 finish;top coat
1 L4 R. a5 h/ x: ^6 ?9 M) s清漆 varnish& n8 p4 X% Q* Q& C- }5 i' s1 O
透明(色)漆 colored varnish' ?' l: I4 G2 A) f: E
溶剂型涂料 solvent based coating
( n: U8 |4 D2 P水性涂料 water based coating
# t% k. D' ^7 w/ s. ^% t粉末涂料 powder coating) X& \) W+ w2 o; s/ L) _0 x  A; i
双组分涂料 two-component coating;
! |: s' E0 Y$ f' Z! U, N! s! Q4 W双包装涂料  two-pack coating
2 y6 C/ U% M3 ^+ S& Y漆料 medium; vehicle
% h4 l. T5 B+ e6 u2 r; r  N漆基;基料 binder
9 @0 [0 ^. D/ D1 u; U成膜物 film former;film forming material
5 `/ G: r/ C2 D# W$ R% w: U  {- X树脂 resin$ Z# L$ r0 O1 X$ J" N/ ]6 G3 ~
天然树脂 natural resin
) d0 V4 a, W+ @8 |: q, [+ |1 N1 d0 w合成树脂 synthetic resin' u8 b/ X7 r7 n
改性树脂 modified resin
: a7 R# [" a6 x6 K, x增塑剂;增韧剂 plasticizer
8 S2 k" h) _$ @6 h* W溶剂;真溶剂 solvent
7 s/ ^: d" {) |& v# R* O6 o助溶剂 cosolvent2 r% M/ g8 I/ g  a
冲淡剂 diluent/ n. K+ Z& x" c2 o  K* z- j, a
稀释剂 thinner
) g" ?/ ~( w" |  ]( ]2 x2 L+ c颜料 pigment
1 C. I4 f1 v) y' |; Q$ k无机颜料 inorganic pigment
) `6 ]( e. g7 k9 O7 y1 a有机颜料 organic pigment/ ?! H8 Q0 _/ ]& t4 ], t& W5 e
体质颜料;填(充)料 extender; filler
3 M, V/ V9 ~. U* ^0 [( y" m染料 dyestuff
- y6 V: X! m3 q: g  o. p$ l催干剂;干料 drier1 a- j& S' V3 o) n% l' G* d, F
底材;基底 substrate/ ~; R% _/ S% F3 J" _/ M6 o( s
涂层 coat
$ ]% C, F4 C+ C/ A/ g- z隔离涂层;封闭涂层 barrier-coat;sealer
2 y9 c& s9 S! x6 ^8 C底涂层 priming coat
) h" N; r" g+ n" a+ t7 _中间涂层 intermediate coat1 F) D$ `& m1 p3 }  W
面涂层 finishing coat; top coat2 b1 `( w  F* ]4 l* n5 J; p+ s
漆膜;涂膜 film; paint film$ P9 x8 {/ A8 _* k' Z
干燥 drying( v2 `1 h4 q5 K& [
自(然)干(燥);(空)气干(燥) air drying
( Y" ]8 w6 O) K$ B, m3 B烘(烤)干(燥) baking; stoving
$ W3 E; `+ V: B2 o: ?  A色漆或清漆配套体系 paint or varinsh system
3 g8 R/ G7 {( k6 r7 Y0 |" R0 B
) B4 y- G9 ~9 M; e" Z# @颜料体积浓度(P.V.C)   r( F. L* q9 A' P3 N
pigment volume concentration(P.V.C) ' t) d3 r# ~9 ~) |' J
临界颜料体积浓度(C.P.V.C)
$ |/ w; [2 ?- i0 A6 y0 wcritical pigment volume concentration(C.P.V.C) 7 p1 _* Z( p' B, F- I
不挥发物 non-volatile matter
% i# [" I( G3 [* H挥发物 volatile matter: x8 C7 x: V/ }. ~- L# N# E
颜基比 pigment/binder ratio4 ~- q0 X6 d6 s' k3 u# y
适用期;活化期 pot-life
: r, }+ p9 d; q' w: H最低成膜温度(MFT) minimum filming temperature(MFT);
% |" X7 v) \. q3 P minimum film formation temperature(MFT)
% ]: j6 k$ l& @: I" j" N: l固化 curing
2 V7 n" M- X  z* z油度 oil length; oil content
: I: L; g( G" S7 Y7 J, s( a, R9 y实际涂布率 practical spreading rate% B: \5 s* I3 Z4 ^
树脂术语
& l. @* Y9 z  e! y% k) I( X: Y热塑性树脂 thermoplastic resin- B3 E4 l; F6 k6 w% C* b
热固性树脂 thermosetting resin7 d9 N6 w0 E4 c, N! k0 b" G
水性树脂 water-base resin; water-dilutable resin1 G2 m  H- i0 G3 q0 B
乳液 emulsion
# H. y' V2 O- N5 h! f$ P4 l2 p乳胶 latex
% |7 q, L' ^8 y: O+ Y油溶性树脂 oil -soluble resin% O" f; k5 d* K/ ]
醇溶性树脂 alcohol-soluble resin( E" h1 S. g( I4 e2 Q
水溶性树脂 water-soluble gum
/ j; a! ?  t0 o" @" V松香 rosin;colophony
4 D6 i3 f7 Z' g/ r, R松香钙皂;钙脂;石灰松香 lime soap; limed rosin
8 B2 s" g" z) S" _+ {7 X. ]松香酯 rosin ester
3 D1 L( A3 V- V. I) Y! K7 ~松香甘油酯;甘油松香(酯);酯胶 rosin glycerin ester; ester gum1 j0 E' O' Q% w+ l% R
松香季戊四醇(酯);季戊四醇松香(酯) rosin pentaerythrite ester; penta resin9 m. J6 x& X3 I: S# U* Q" v
顺丁烯二酸-松香酯 rosin-maleic ester; penta resin/ \% K  x8 @4 F/ v
中国生漆;中国大漆 Chinese lacquer; j+ ?- w/ \6 m$ m5 H! U9 [' n0 h
虫胶;紫胶 shellac; lac( n: A, @& W- x! c
(乳)酪素;干酪素;酪朊 casein! I; E% X# j$ ]8 d
) T# t1 i2 w% n; n化石树脂 fossil resin
+ a7 Y4 z. k- o3 Z6 k1 @4 z钴[珂]钯树脂;钴钯胶 copal resin; copal gum# Q: R& A' d& m( S0 k' _/ X: _
达玛树脂;达玛胶 damar;[dammar]; damar [dammar] gum
5 }  s; T3 _$ F3 k$ n( x  e呋喃树脂 furan resin/ W3 c0 r/ \$ P1 q( Q
糠醛树脂 furfural resin9 K" [2 H5 e* S
糠酮树脂 furfural acetone resin: k' N' M" J  e- e& o
糠醇树脂 furfuyl alcohol resin; (furfuryl resin)* T4 y# ^0 S3 O, ]& _
沥青 bitumen; asphalt; pitch$ G- h2 O, u: Y$ S1 s/ }
天然沥青;地沥青 natural asphalt4 V- x& a" F- c. W1 i) n
石油沥青 petroleum pitch; petroleum asphalt
+ m0 [" t; N: |3 q(煤)焦油沥青 coal-tar pitch
( |8 j. ]6 T- _- t木焦油沥青 wood-tar pitch4 c. M4 Q! n* R7 w/ H% P
氧茚树脂,香豆酮树脂;古玛隆树脂
- h6 V$ M( j( ?' y! N& jcoumarone resin; coumarone- indene resin 6 @* Z. ]- X% N' F- o
石油树脂 petroleum resin
# q/ P* z" [$ f; X( }- Z$ o/ T% i! }: [二甲苯甲醛树脂 xylene formaldehyde resin( J7 e9 p3 ~: |. w. C; r, b/ @
酚醛树脂 phenolic resin4 n5 h( c2 z  }/ q6 B) g" K
纯酚醛树脂;100%酚醛树脂
; Y/ q4 S1 \* \1 d* R- L6 A* apure phenolic resin; 100 per cent phenolic resin 4 Q; h- o4 \" B- `: u5 P
苯基苯酚酚醛树脂 phenyl phenol phenolic resin
3 ]+ j* Q8 x# l* T9 t! D4 k5 w树叔[特]丁基苯酚酚醛树脂
0 K+ b1 E8 R- u# t1 S( Gpara-rertiary butyl phenol phenolic resin
" e; }0 b+ K1 `! r' n4 ]改性酚醛树脂 modified phenolic resin5 a- u" ?* f" v9 i/ M! A( {
松香改性酚醛树脂 rosin modified phenolic resin
. X. I8 [3 Z# }0 ?. I6 A7 d丁醇醚化酚醛树脂 butylated phenolic resin
2 n% T6 b1 c$ [3 H9 p/ M醇酸树脂 alkyd resin
! [' _$ {. y4 ~# w7 U1 s- }干性油醇酸树脂 drying oil alkyd resin
) i1 ^0 S* n# J* D  I不干性油醇酸树脂 non-drying oil alkyd resin& U; C6 ]2 {; R" I* ~8 k
改性醇酸树脂 miodified alkyd resin; \% A; s/ L. R! x% K8 l% j
长油醇酸树脂 long oil alkyd resin- Q/ A  j( F0 u9 }4 M7 ^! M
中油醇酸树脂 medium oil alkyd resin
  M% M! R% m3 f/ y% y7 a1 K1 X2 l短油醇酸树脂 short oil alkyd resin8 ^% ?; ^+ F/ |3 I
氨基树脂 amino resin
6 n, M4 I5 O( B# G7 c7 P+ {三聚氰胺甲醛树脂 melamine-formaldehyde resin4 ^! b( M+ A/ I* \" N9 s; g+ D! r8 W
脲(甲)醛树脂 urea-formaldehyde resin
+ k% n6 d0 F7 ]1 K烃基三聚氰胺(甲醛)树脂
% y1 M- v% J' y" A$ q6 `hydrocarbon-based melamine (formal-dehyde) resin
3 W# C; j, w/ \8 q4 g) }苯代[基]三聚氰胺甲醛树脂;苯鸟粪胺甲醛树脂 8 O& ]; h( P, B% R" C
benzoguanamine (formaldehyde) resin
2 \1 y- a- i7 v* x0 Q尿素-三聚氰胺甲醛树脂;三聚氰胺脲(甲)树脂
. d- S$ p3 T9 E% Gurea melamine formaldehyde resin
8 W* A7 {' l' y8 H$ p/ s纤维素酯 cellulose ester
6 y8 M% `/ Q+ h: k3 G纤维素醚 cellulose ehter
+ h/ @3 P0 Q6 X9 z$ G" G硝酸纤维素(酯) cellulose nitrate; nitrocellulose, E& B+ z0 b' B( W& L! T- |/ B+ c
乙[醋]酸纤维素(酯) cellulose acetate
( D4 Q' i' C2 o; e7 M丁酸纤维素(酯) cellulose butyrate) `3 z- R" g( l2 t6 \
乙[醋]酸丁酸纤维素(酯) cellulose acetate butyrate; * x8 @9 i; |$ z6 T' Q! f
cellulose aceto-butyrate
" ]( P/ f7 L1 I2 e, p乙基纤维素 ehtyl cellulose
  o9 f4 [. s, j0 F* o; [. L1 ?苄基纤维素 benzyl cellulose+ J* p, U4 a# \( Q9 V) P( Z
乙烯树脂 vinyl resin+ r6 A- A4 B( G
聚氯乙烯 polyvinyl chloride
) g, E) W2 t1 C过氯乙烯树脂 8 ~; f8 ^! T" H0 T8 e! S3 |
post-chlorinated polyvinyl chloride resin
0 ~' ~7 n+ I& _5 z3 s苯乙烯树脂 styrene resin
5 `3 y; T: A7 _6 b$ s! i( ?聚乙烯 polyethylene
+ H6 C) W: y" q- S9 p  K) {氯化聚乙烯 polyethylene
) ^) d# V/ j; Q6 j1 M; Y聚乙[醋]酸乙烯(酯) chlorinated polyethylene( E" m) |* l4 W( p' o# t* W$ \
聚乙烯醇 polyvinyl acetate
6 }+ b0 ^3 x/ ~- P' q# |1 r聚乙烯醇缩醛;聚乙烯醇缩乙醛 polyvinyl alcohol( I. j9 U' [& V, O/ t/ u( N
聚乙烯醇缩甲醛 polyvinyl acetal(s)! _2 h  c" A& I7 L
聚乙烯醇缩丁醛 polyvinyl butyral6 p% a9 P  r2 n& G) M, ~
聚丙烯 polypropylene0 }6 p/ D6 J. A) e. x
氯化聚丙烯 chlorinated polypropylene
3 V6 {) p9 n7 i/ W0 Y' U' V7 z/ n聚二乙烯乙炔 polydivinyl acetylene
$ N5 m9 }7 C6 `. t氯(乙烯)醋(酸乙烯)树脂 vinyl chloride-vinyl acetate resin
, n" M6 R: G4 _0 G+ ^7 D5 Y氯(乙烯)偏(氯乙烯)树脂 vinyl chloride-vinylidene chloride resin
0 r) T( {! k4 w% a& e% D偏氯乙烯丙烯腈树脂 vinylidene chloride-acrylinitrile resin
+ f5 M" j1 n! D# L) T丙烯酸酯树脂 acrylic resin
/ x$ E( n+ w1 S  h, ]: m聚酯树脂 polyester resin3 j3 z, k+ H8 Y
饱和聚酯树脂 saturated polyester resin
9 s9 C) h2 G* y4 S6 {  ], d. J不饱和聚酯树脂 unsaturated polyester resin
' o) y0 x5 d' ~# n; s- Q聚碳酸酯 polycarbonate1 ]& q9 G3 j! F6 f' I' \" y
环氧树脂 epoxy resin( G+ i5 u1 F+ {0 K
二酚基丙烷型环氧权脂 diphenylol propane epoxy resin2 S3 e! _4 ?2 k
线型环氧树脂 linear epoxy resin
9 I4 w  d: m1 J7 Q: w$ j非二酚基丙烷型环氧树脂 non-diphenylol propane epoxy resin
) L( X5 D7 p7 ]& p9 T1 u  W( W% O脂环族环氧树脂 alicyclic epoxy resin8 t" y  h- y4 C+ A
环氧酯 epoxy ester
) y$ Q) ~0 k: S6 x5 g3 K' V7 O聚酰胺树脂 polyamide resin
0 g6 w8 _! E# E8 e9 ~  _2 Z异氰酸树脂 isocyanate resin4 r0 C2 r' V0 i+ e- V9 u) l! F
聚氨(基甲酸)酯树脂 polyurethane resin% b$ T) n- D- {$ S4 G
有机硅树脂;硅树脂 silicone resin; polysiloxane% x5 V& @  F; m& S. H
氟树脂 fluor resin
, t& {2 B+ G% ?' h# ?% `) F聚氟乙烯 polyvinyl fluoride2 ~8 g& G% a$ x' H, o/ a
聚四氟乙烯 polytetrafluoroethylene
1 p/ `$ V) M9 f聚三氟氯乙烯 polychlorotrifluoroethylene;# |% w, z2 d) E
  polytrifluorochloroethylene
5 q- K. z" h# w- N6 ~有机铝树脂 organoaluminium resin
' ?7 e0 E. t- s4 B: I有机硼树脂 organoboron resin7 T0 ^  Y9 i" M, C/ @2 w4 {9 k0 h
有机钛树脂 organotitanium resin
, O+ H% S- D8 Y5 M2 y5 s/ t$ W橡胶类树脂 rubber resin
+ F, z- u4 t( h  I0 R( B; }氯化橡胶 chlorinated rubber7 }/ I" g9 v, b! {
环化橡胶 cyclorubber, cyclized rubber
; {8 o6 G7 M0 g/ t丁苯橡胶 butadiene styrene rubber
. c  u2 W7 s3 S4 z0 S6 [氯丁(二烯)橡胶 chloroprene rubber; polychloroprene
) V# v; c& ~* Q% t* a丁基橡胶 butyl rubber5 j2 \1 X' z5 @4 v4 {0 d% O7 o
丁二烯橡胶;聚丁二烯 butadiene rubber; polybutadiene
8 N4 L) q  b; P" Z( r0 V& K丁腈橡胶 butadiene acrylonetrile rubber;
! v! g+ H1 g/ n' X; ~$ S1 V  acrylonitrile butadiene rubber$ p6 b* ]; r5 U
氯磺化聚乙烯(橡胶) chlorosulphonated polyethylene
. R1 W, ]1 o( l) K- J0 E5 h聚硫橡胶 polysulfide tubber
: ?) p* r5 G8 r0 j& D; q氟橡胶 fluororubber
( C. A! ~1 H7 j. C( U" b( @聚酰亚胺 polyimide
3 M2 _* R: x) ^# T- n聚酰胺-(酰)亚胺 polyamide-imide
5 L. R* O3 Z! R- p- N聚酯酰亚胺 polyester imide
- c2 T1 Y) `# W% R" S聚苯并咪唑 polybenzimidazole! K7 N! l. n5 J
颜料术语
* W) ?5 H: e' O$ i天然无机颜料 natrral inorganic pigment
6 ?, V- |: @3 Y9 F, o合成无机颜料 synthetic inorganic pigment
4 L1 \/ K! |' g' ?) k& t4 `9 ^3 R天然有机颜料 natural organic pigment
7 ~9 C9 _. Y/ A  m合成有机颜料 synthetic organic pigment
7 [0 C. c8 _6 Z/ e5 y3 X' C天然体质颜料 natrual extender
! m4 O# _& H7 {" l% l; ^合成体质颜料 synthetic extender
9 Q  G4 C1 X; Y0 h! v8 {白色颜料 white pigment  u2 q7 }6 l8 R$ |* m. B# y
黑色颜料 black pigment
, W# c+ R! s' {7 B% g$ N" e彩色颜料 colour pigment' K  B# M- {3 n/ c
珠光颜料 pearlescent pigment. k* Z- j- g+ D4 b, ~5 F6 X7 P* Y
发光颜料 luminescent pigment2 ~# T/ [) c5 @4 L
荧光颜料 fluorescent pigment. i% _' p5 F  s
磷光颜料 phosphorescent pigment
+ a2 b7 r& c3 g6 l( E防锈颜料 inhibitive pigment  e1 ^: {: Q9 k2 I
防污化合物 anti-fouling compound
: @: `+ f1 I0 n9 M: y/ a) m包核颜料 core pigment/ c* g9 s" V: W5 V& L
示温颜料 temperature-indicating pigment
. R1 K( d0 ?# J: |. p1 z' }6 J4 c. R透明颜料 transparent pigment/ L( T$ B8 A" C3 `" N/ @1 _5 @
金属颜料 metallic pigment6 J; j5 Y7 }: F& Q) @
浆状颜料 paste pigment
$ c; P/ P0 s( A9 _色原 toner' o9 p4 e$ X) r
色淀 lake colour 7 s. d! y. o, g0 z( E! e& m
二氧化钛 titanium dioxide1 Q' w5 j# L2 H* w' u* D* _; z7 s5 ^2 Y
氧化锌;锌白 zinc oxide, S5 @) y& V: @$ n; t3 R6 n) P0 B
锌钡白;立德粉 lithopone
4 {& G  I6 z# [) C! u/ q铅白 white lead
8 p# m" l) [0 B2 X' G4 s! V: x红丹 red lead
% y" p; t% V; ]群青 ultramarine
: u# [) i* c0 g9 u1 {- O; ]铁蓝 iron blue
5 g( |" s) ~' G铬酸锶;锶铬黄 strontium chromate
7 c; A* ~* ]' L2 l% X7 w) D; B铬酸钡;钡铬黄 barium chromate+ W! K0 \# Y% ^# M% p6 X3 \
铬酸铅;铅铬黄 lead chromate
. r  r7 s; x1 C6 A9 `; M3 W钼铬酸铅;钼铬红 lead chromate-molybdate
+ v, h2 Y- U' ^! }% F: H4 q碱式铬酸锌钾;锌铬黄 basic zinc potassium chromate
, Q1 ^( x* ?7 D; O8 _' F四盐基铬酸锌 zinc tetrahydroxychromate5 L/ M9 V8 l' I; ~, g( [. f) Z
铅铬绿 lead chrome green
) d4 T% D) L. t- X( H8 e氧化铁 iron oxide pigment5 U: i- a' U9 }9 w3 m9 P* |- Z
铝粉 aluminium powder. s. R; H3 N. i$ o0 x
锌粉 zinc dust
& c( i8 ~3 `# W4 g$ ^, j& B2 T二甲苯 xylene4 F1 E8 r; |6 N& o* h7 S5 c( f$ a2 J
甲苯 toluene* w; c. V* Y/ Q# Y0 @
醋酸丁酯 n-Butyl acetate - w/ r: O, A) @9 [* V+ _
丙酮 acetone
* U0 z. g, w( I' M甲乙酮 methyl ethyl ketone
% I! {+ V9 [  k0 [环己酮 cyclohexanone4 [. @+ s5 F2 \- @  @
异丙醇 isopropyl alcohol4 `. p: \' x. O, B6 m+ `
正丁醇 n-butanol$ N! T8 J5 v/ R# J) L& M0 p6 ]
正丙醇 n-Propanol8 b0 U( L. ?3 O2 x8 A
苯 benzene2 K$ e( O. r4 e
偏硼酸钡 barium metaborate$ O2 m3 D' v1 {
酞菁绿 phthalocyanine green
# ]  T3 l8 F5 i7 y2 I% c* W' T酞菁蓝 phthalocyanine blue$ A  G, G# H" n3 s" Q+ z7 l
大红粉 pigment scarlet( a. T" J5 w% V  C1 c# g- A( K4 `  B
甲苯胺红 toluidine red8 l- j5 t7 U4 O% n) J7 g$ y
耐晒黄 fast yellow
5 L9 t) G$ k% r; B6 d* R联苯胺黄G benzidine yellow G
+ T: p, ^" B5 r7 S' f重晶石粉 baryte(s)8 Q1 I. H. X' t+ W. \  @6 f
沉淀硫酸钡 precipitated barium sulphate4 C8 Y8 Q( A9 z/ Q
天然碳酸钙;大白粉 calcium carbonate; whiting
! v4 ^: b/ M7 p" E2 h+ X& d结晶碳酸钙;冰洲晶石
 楼主| 发表于 2008-2-28 00:44:24 | 显示全部楼层 来自: 中国福建漳州
crystalline calcium carbonate; Iceland spar . {# ?. |) Z7 A4 v$ S7 p. A
沉淀碳酸钙;轻质碳酸钙 precipitated calcium carbonate
. N: N1 D$ ^% [( y白云石;碳酸钙镁
8 z2 Q/ t" i% G: h& j* e& |6 pdolomite; calcium magnesium carbonate 9 w* q+ L( I3 I) }* |/ M, x0 z+ P
瓷(粘)土;天然水合高岭土
' S% n9 P# @( M9 ?- v8 S) hchina clay; natural hydrated kaolin
2 r+ w8 f5 y- `$ t. t滑石粉 talc powder
& o3 S2 W3 ?. W. D$ d$ F云母 mica
4 `: F; P. ^8 d天然二氧化硅;石英粉 natural silica& i% ^+ u$ b- r2 Y' z
硅藻土 kieselguhr
2 b8 S, Y& p4 J  ?0 [( M. C- E1 l合成硅酸钙 synthetic calcium silicate7 B' D: P: _  c: k' p9 u; W* i# X
合成二氧化硅 synthetic silica6 a0 a# r! @0 t! |
石棉 asbestos2 j7 s: h. W; C- m+ c
色调 hue
/ J$ W6 U  W* G: r+ c" r6 l# Z  ~明度 lightness* @) g* y. o% ^4 ]1 ]. L
饱和度 saturation
# Y* L* A7 U4 X. N! ]2 T颜色匹配 colour matching" E6 G- X" g9 }
互补色 complementary colour3 A4 W9 O. }; W+ e
色差 colour difference
. ~) F% |) H* k9 J( f  x" s原色 primary colour
! T! \3 P0 B6 @1 f4 \; w& N底色 undertone" n9 @  Q9 `' B# u9 l; l6 q* M
主色;本色 mass-tone; mass-colour3 d- y% X& T9 }5 f
着色力 tinting strength
. y2 |) r# ?; s. l3 {消色力 lightening power
9 @& o( D& F, N; Y1 Q! i颜料密度 density of pigment
. d) r# P' y1 K8 a7 a水溶物 matter soluble in water
* l1 u' z, F% t$ L0 ~( X+ r装填体积 tamped volume
7 z5 v- w0 O: \吸油量 oil absorption volume7 @# m; M# l6 ], q9 f$ H
筛余物 residue on sieve" f5 a5 N0 n9 z
筛分粒度级 sieve fraction# u0 B# g& k6 j( ?# f
絮凝 flocculation( H. D( Y: A2 t8 b5 Q
分散性 dispersibility, s4 n( V$ S  v3 a+ h4 ~9 s
易分散程度 ease of dispersion
% p3 l* v6 z5 X. [$ Q( u# W挥发物 volatile matter of pigment
" W7 o( c5 j% m" s6 O耐光性 light fastness9 ^3 P" O, s; d( y/ ?: _8 ?/ w
耐热性 heat resistance$ v; @3 u; V7 p+ k# h1 t' _- C
耐化学(药品)性 resistance to chemicals
. l% b: [- i, G( y0 x遮盖力 hiding power) y( f2 H2 y' c5 |5 V4 r
渗色 bleeding" K8 w7 e, N6 p6 O! h8 `, D
铜光 bronzing
  ?( y& X- P, t9 b/ J水面覆盖力; water-covering capacity;3 x' h+ P$ u( s/ i+ d
叶展性  leafing
4 H4 R# F! c9 Q3 y: I; `( I酸度;碱度 acidity; alkalinity
: w. u* ~; q& f$ I5 H9 I润湿 wetting
/ ]0 V; b& H: t8 T表面处理 surface treatment  q) B* \" D" Z8 o  a( d/ `
涂料及涂膜物化性能术语 ; n# P. h8 V6 [9 I. g" \
透明度 transparency* h4 |8 ]- @! V) V
透明液体的颜色 colour of clear liquids) M) B% j/ o0 z: F  {; M
密度 density ( p2 r* d6 j6 x3 v  `
粘度 viscosity
4 J' T3 D9 P, S( @动力粘度 dynamic viscosity
& c, g  m+ T7 a% O, R运动粘度 kinematic viscosity7 r0 t1 T; F# y( @8 r3 h
流出时间 flow time
8 j+ I+ H! R& _# `流变性 rheologic property
/ V( r  X3 k: C/ p触变性 thixotropy
! \1 C8 X0 K6 H  _/ K闪点 flashpoint! e4 B' L& X0 a
酸值 acid value
/ w1 t+ V5 t% I# D( f, x羟(基)值 hydroxyl value" b1 J3 ^1 B0 |" J. j. Z; d
皂化值 saponification value
" f1 O' Y6 f: I胶凝数 lacquer thinner gelling number' n+ _* T/ V- |+ c& ]" ~$ [
挥[蒸]发率 evaporation rate; volatility1 D& e( w" n: M$ g
研磨细度 fineness of grind
/ X# ^# |3 Q6 J1 k+ q% |不挥发物含量;固体含量
' M4 [  I8 W: f5 snon-volatile matter content; solids content 6 ^& N' r0 k  x& f! g
涂料水分 water content of coating+ c- v  K- D) v* w0 d
耐冻融性 ash content of coating
+ ~; H" Q9 R( Y( C2 D容器中状态 freeze-thaw resistance
, d) t# I7 ^" V$ s8 H# F贮存稳定性 storage stability0 u& b" D) l0 o& ^# j" V# E
相容性(产品之间) compatibility (of products)
  t( {2 j+ M7 c9 l( _3 x适应性(产品与底材之间) " k5 J  [2 C+ H& b' D% C" c
compatibility (of a product with the substrate)
% V+ i" b+ g" f  b遮盖力;不透明度 hiding power; opacity
5 R9 u8 d% K2 L6 E1 Z/ S8 A0 A0 t对比率 contrast ratio
: ^" j  Q& l* N6 U2 b" T- u表(面)干(燥)时间 surface drying time
( ?3 `" x0 `  O0 X实(际)干(燥)时间 hard drying time- V8 D  e# a( S: C5 @0 y% z( T+ c) F
施工性 application property
8 k3 }4 r; i- i% R刷涂性 brushability5 M" _: D% u1 J( x0 P5 o1 O7 a; x
流平性 leveling; flow
! a# g; i+ N& ~5 l) f/ N$ P重涂性 recoatability
0 F9 \, U# R' S! m防白性 blush resistance2 y! h3 [. u$ B# q, a2 l
漆膜厚度 film thickness
& Q& @7 ]2 |4 R( e! \- ], s3 J0 r$ U( N老化;熟化 ageing5 M% Z! T9 z$ v: @
光泽 gloss1 Z3 c$ M7 G) T$ E" s" U
平光[糙面]光泽 sheen
3 i  r1 w- b8 G' [1 x0 K: w$ p7 c附着力 adhesion$ M* l7 F* k9 s. ^4 E
内聚力 cohesion
. V1 y6 z9 Q9 u' n, |硬度 hardness
& B4 J& B0 y3 V5 A+ s# v2 p" m柔韧性 flexibility- B$ X8 g9 H5 U' S- v
抗冲击性 impact resistance
9 b- l- d8 L6 _* c3 S+ ]6 g' L抗张[拉]强度 tensile strenth
/ Y* A" S8 F- W/ C. |伸长率 elongation
* P* V# g* J4 ^$ F耐磨性 abrasion resistance
; T4 a3 K) Z$ Q8 a4 h* F打磨性 rubbing property+ I7 V! j2 c6 S7 y
磨[抛]光性 polishability
% y9 g+ {8 s$ C7 b4 K5 D* r耐水性 water resistance6 K8 }- w0 Q! \) q3 W* |
耐洗涤剂性 detergent resistance9 a0 k. x' O& w6 S4 M; @
耐腐蚀性 corrosion resistance, s1 O  p1 x1 D9 `3 N" N. s
耐化学药品性 chemical resistance8 j& v( k$ H/ d' A7 T
耐酸性 acid resistance
  s# c% H+ w4 B1 N2 L) Z6 ^耐碱性 alkali resistance
5 i$ p' V' R9 p0 _6 b; K4 c耐溶剂性 solvent resistance3 O- t7 \5 l; ~, u. B
耐润滑油性 lubricating-oil resistance# O) o1 P( j* v5 C0 r6 P
耐汽油性 gasoline resistance
" D  l+ f* j! `3 T+ V0 P抗污气性 gas checking resistance
+ z5 g: l! r6 w# A耐盐水性 salt water resistance
0 O% I' h; y0 w+ S耐盐雾性 salt spray [fog] resistance0 E) r' U9 ^/ L5 _* c8 ]
防霉性 fungus [mold] resistance) m, K: U) v4 F1 D+ k3 o( o8 `8 ]
耐湿热性 resistance to heat and humidity8 ?- s6 c3 ~& p1 d" \
耐候性 weathering resisitance. \+ q6 A7 Z1 j0 V9 G
天然老化 natural weathering8 \7 b8 n9 Q6 ^5 z- n4 c. ]# g6 s( m
人工老化 artificial weathering- n- S) g) k* J
抗粉化性 chalking resisitance
6 I' q8 {: A! ?' H+ e7 Z耐光性 light fastness; light resistance
. }) Y" x0 ^3 ?2 K9 I( o保光性 gloss retention
. x& T6 \+ W+ W& }保色性 colour retention1 @+ Q8 e8 T. h  P& U- m( r
黄变;泛黄 yellowing3 ^( C  P' s) }1 E' G5 V
热稳定性 heat stability
+ f, g: h# k+ w" T  G/ S8 H耐寒性 cold resistance
6 ]% ?% V$ p2 M* F. _5 T耐温变性 temperature change resistance
( H3 a# ]- A9 w) \& d- `' ^0 |耐湿性 moisture resistance& P% Q# q+ R5 ?) E+ y: O
耐干湿交替性 humid-dry cycling resisitance
6 k; g4 o" n. @, T水气透过性 water vapoiur transmission% c8 X# o+ z4 R- w- v: b2 n
水气透过(速)率 water vapour transmission rate1 E& [  K" Q0 j/ ^! B4 ?
耐硝基(漆)性 nitrocellulose lacquer resistance% e/ I/ e' Z1 R# s/ B' b
, z1 X5 h8 ]8 S$ T. E耐燃性 flame resistance' d6 _6 d2 g3 ^2 c9 S) w2 H
抗辐射性 radiation resisitance$ _) k- r8 y( Z3 W. S
抗放射污染性 anti-radioactive contamination
( r  c$ n" R/ x% j" L3 R可剥性 strippable property) V4 g( w6 J  [
耐海水性 seawater resistance0 y& v- Q0 R3 S! u+ ]0 d& D
防污性 anti-fouling property
% _7 ]( ~: m1 B+ P& O渗出[毒]率 leaching rate
- [$ H" y1 W0 j防滑性 skid resistance: N! J# E0 r& V; O! P
可洗性 washability
  z0 h3 y6 l: m- O; s耐擦洗[洗刷]性 scrab resistance1 z6 U. y& S3 S$ v
电绝缘性 insulating property5 E3 P0 g7 a  a! d* J& c
击穿电压 breakdown voltage, l7 ?3 r0 R0 j# J+ [" q
电气[介电]强度 electrical strength;
  }; d3 I/ j9 @8 [& A3 T1 b+ x; O2 P  dielectrical strength! L* k4 ?5 D, j' w
介质损耗[失]角正切 dielectric loss tangent# \% ?% w. K9 i% M: Z  E6 |; |
表面电阻 surface resistance
# @) y4 ~0 \6 u5 ^体积电阻 volume resistance! F, P5 z4 k3 l
绝缘电阻 insulation resistance  R1 E/ P$ E! t" i  n1 t- G8 J- Z
表面电阻率 surface resistivity  K& Q7 j  f5 |$ ]8 y% O
体积电阻率 volume resistivity' ^' M9 @8 }2 O8 V
吸水率 water absorption rate- G2 o; a, Z( e, E
耐电弧性 arc resistance
2 Q6 \' f, u" I* W, e" v2 V耐变压器油性 transformer oil resistance; G( r& P7 }5 d, D% [
抗甩性 anti-centrifugal splash
; g. D1 q2 e, T- x8 G8 X电导率 conductivity
/ }& O$ y7 ~3 ?) W- t(电)沉积量 electrodeposition weight! z1 X  }2 T& }) @( ]  |1 u
库论效率 Coulombs' efficiency! K: F2 e' ^, s: @
泳透力 throwing power
% q  A( H( b7 ~0 o涂料及涂膜病态术语 - |: E  ^9 X- ~4 q- r& q
发浑 clouding
( u2 R. Z; Y0 u* l原漆变色 discoloration of paints or varnishes
: T; R7 N( @/ C5 ]% [0 `) ]增稠 thickening, O( i: ~( ^4 U- R" p. X0 }( B8 H( z
变稠 fattening/ i0 z8 A7 `9 a, W! x
肝化 livering; feeding
- V  _: Q' a# u: k+ }絮凝 flocculation% M4 O0 I3 C# ~# x5 Q1 v
胶化 gelling
. d; W  V! x' u; x2 I$ ]晶析 partial crystallization
( }5 x7 h1 \; m1 }2 n3 t( W! R: l结皮 skinning
+ N- p' U  I( @9 k6 H沉淀 settling  q! A! ^. x3 v1 w
结块 caking! b* K9 A* p* f
有粗粒 seedy
. ~6 N) t* n- O, u( U! J- x# V5 U7 r返粗 pig skin
( U! O" U. P% D3 d4 v! \发花 floating
9 G: H- x8 C* O. n- W浮色 flooding
4 Q3 m, X0 U$ R" c/ w- K起气泡 bubbling
  Q. y. T2 _6 m  }/ _7 x3 n5 _& P, i/ {针孔 pin-holes3 Y( Y% G' e0 O3 ^2 x3 v1 ^
起皱 wrinkling7 C. b' q9 g/ ^# ^. x! I
桔皮 orange skin
% S+ h8 ^4 G8 w6 h3 o  j+ f7 S发白 blushing
2 k$ R5 L) N) r流挂 runs; sags; crutains8 ~' C$ o8 H. t  S" u  \4 `$ s" P
丝纹 ropiness
; [5 r2 u, p" O$ B; w% c刷痕 brush mark
% H0 x, E5 Y* H0 a2 b" ]收缩 cissing
8 Z# P" u( }' b7 ~缩孔 cratering
2 s$ s4 O) B6 v4 a3 \厚边 fat edge( j0 f1 d2 ]  H
蠕流 creeping* D9 s2 s% R' K4 k# ~! M
漏涂区 miss( s; [0 E8 T3 _. N' c
接痕 lapping defect2 c: w, h5 A) K
堆漆 piling; ]+ p( d$ C& S2 m1 [! \6 {( ^
咬底 lifting# x" y3 ~. ?7 {
渗色 bleeding1 J# Z; g; E" J+ U
不盖底 non-hiding, X! |  O( A& l% j0 B
残余粘性 residual tack: f% Y" M* t; _  c- s( K
闪光 flashing
9 ?$ [! ~5 F9 D, K' V渗出 exudation  y7 _0 D* s1 Y- V; r# {* U
干酪化 cheesy% L' Q  a8 k6 n2 m; s( |7 x% s
表面粗糙 bitty appearance& a, P0 @1 Q+ T
积尘 dirt retention. q/ c9 R+ J6 Y7 ^
起霜花 frosting
4 S) a4 ^  I: N污气网纹 gas checking ' u4 _5 x  ]( e7 [' j  b0 Z1 \
爆孔 popping: ]+ q/ m6 e4 N* ?) o
泛金光 bronzing
! t* I5 W; H* e" B/ w" b8 N漆膜变色 discoloration of lilm' |1 t# b# B3 c1 l# u7 i1 k
褪色 fading
4 y) _' a1 Z  w$ ^) }3 R( E; C漂白 bleaching
9 L# w' _, @6 Q: m; L7 r8 w$ Y黄变  yellowing, ^& _5 u/ @* U$ v2 g$ s  j# }
变深 darkening9 t" I4 ^+ i9 T, x) }! \" D( g
破坏 perishing6 m4 ?3 d9 T4 z' o/ K
起霜 bloom
* k- q0 g8 A) }# y( U0 I失光 loss of gloss
; q4 `, y$ U4 t( @3 d变白 whitening
, N. X9 s- R' \8 S7 Q! H; |溶胀 swelling
8 }9 A' Z7 v8 Q; p% P+ Y( j6 m- e软化 softening
0 j1 D" t  O! j1 u! a( O3 l9 k起泡 blistering
) t% [' k- x: E& B7 J开裂 cracking
9 u$ ^' [; [2 {) D/ k, ~. ^$ u微裂 hair-cracking3 L/ ?, k9 o: T) f  Q) Q
细裂 cracking7 z* K) \' i8 J  P, ]1 ]
小裂 crazing
+ z. K- m2 y0 D' y$ L( I深裂 deep cracks5 K3 b1 ]- w  K1 L8 v
龟裂 crocodiling(or alligatoring)
( Q8 D- o( M8 z: n" {鸦爪裂 crow's foot cracking
) T2 n7 h  A1 x! B/ h9 K, f剥落 peeling
: N2 s* O3 n: M片落 flaking
# Y. X& a) c* j8 D. K侵蚀 erosion8 {5 |" `" f) a7 w$ L
粉化 chalking
4 b$ g2 N2 q' t/ X" C  \4 ~* x% T. Y脆化 embrittlement
5 W# A  T  R+ Y$ \: w8 {6 l回粘 after tack2 S6 ~; W# V6 V
污染痕迹 stain
- b, N, K2 b9 G丝状腐蚀 filiform corrosion7 c8 r- l+ Z! B, R+ V
长霉 mildew-growing,# b. f$ y  x; [( Q& e1 p0 {
  fungus growing, mold growing
3 b7 U. n5 d: z1 ?7 I1 o7 R) \生锈 rusting$ U8 P6 K% Z) `( r2 N
生白锈 white-rusting. T& G& U+ \9 `" m% H& H  u6 R! [
针孔状腐蚀 corrosion pin-holes
