2022-07-04
2022-03-11
查看: 5350|回复: 4
[分享] NX I-DEAS 6.2 M0 rev1 HotFix
发表于 2012-2-4 19:10:47 | 显示全部楼层 |阅读模式
  @$ h9 O0 F$ o: |% b0 O; }- f. d( N) [$ r( w1 c
2012 January, 19 ; o8 @4 @) K* b1 w
6 c. M3 {1 V4 ?% i% |NX-Ideas 6.2 MO has been replaced by developers for NX-Ideas 6.2 MO rev12 r/ F7 g( P3 ^
) X. Y( l' Y# l) @, x0 i, YNX-Ideas 6.2 MO rev1 resolves the next issues of M03 W4 J2 q1 G5 F0 D. }: L
2 T* I1 G) @0 I6 ^9 n/ O
NX I-deas 6.2 M0 Rev 1 Installation Update( q9 g6 `8 F5 c2 X+ ~+ v; y* Y) c* W
1 d0 T# }/ S* o) C" K7 CSummary:
7 f) S! Z5 P8 t1 z0 `8 nThis update corrects the following:3 i0 `( H9 q' M. v* @
  * Errors within the bin\*.cmd files that are commonly used to launch
* A+ N& X/ q& [4 {6 p8 D& f( `  I-deas products. The scripts delivered with the initial release
. R3 N5 ^6 H' c. n# b, ?6 a9 F0 a  checked for the IDEAS_PARAM15 environment variable rather than6 p% N$ ^; H5 J5 s- k; m
  the IDEAS_PARAM16 environment variable.! B( [  Y- R9 g4 P6 x- p: e2 L0 I
  * Errors within the TDI wizard that would not allow a customer to
2 v! P- O( q5 Z" ^% i, y  connect to an existing TDI or migrate an existing TDI if the I-deas5 b! u' _  t$ M: y5 k3 H; b1 X# G0 `
  SFAM component was not already present on the computer. The new TDI8 J/ ]. G5 w" V. s: R; P9 c
  wizard informs the user that they must install the SFAM component
( N5 p& h) i8 h8 v" J$ ~  from the previous release of I-deas.# g. D* W* c  E0 F3 Q0 s
- Z. y* [' r: e( ?9 \; e: t9 ?% S1 M% AHere is archive with update NX I-DEAS 6.2 M0 > NX I-DAES 6.2 M0 rev1
& d  j$ s; z2 y* s# j! G1 a" S* Q$ P% [; n6 ^
NX-IDEAS_6.2_M0_rev1_HotFix.rar+ r& H! [  V$ i5 M
http://115.com/file/dp2p6ywe#
发表于 2012-2-4 20:04:12 | 显示全部楼层
32Bit or 64Bit,only one?
 楼主| 发表于 2012-2-4 20:10:29 | 显示全部楼层
32Bit or 64Bit,only one?6 ^8 _0 O! K9 W) w
lucklyday 发表于 2012-2-4 20:04 http://www.3dportal.cn/discuz/images/common/back.gif
6 E% E) i! m: Q9 Z+ ?2 GNX I-DEAS is 32bit applicatition/ u5 Q2 M0 m; C
there is no special NX I-DEAS for Win64 (on Win64 I-DEAS works as 32bit application)
发表于 2012-2-5 07:16:35 | 显示全部楼层
樓主辛苦了,感謝分享
发表于 2012-4-14 07:26:44 | 显示全部楼层
谢谢了,很好啊!
