查看: 1136|回复: 0
打印 上一主题 下一主题
[风能] The System of Monitoring and Surveying Meteorologic Environment
跳转到指定楼层
1#
发表于 2008-11-5 09:24:11 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式 来自: 中国湖南湘潭
Abstract:
  e0 j! B; t0 }% d: @% GWind power is a green energy sources as generating electricity, Researching and analysing weather environment about wind field is an important basic to establish wind power item and economic run. The article introduces the research about surveillancing and measuring weather environment system to wind field. Tiny power ACS300MM is kernel equipment in the system. Meteorologic multi-sensors connected collect wind speed, wind direction, temperature, humidity, air pressure and precipitation rain fall. Communications mode is wireless, the ability of telecommunications is strong and dependable, this mode consumedly economizes manpower, realizes no keeper to auto weather surveillance about wind field.
zhouhai.pdf
69.32 KB, 下载次数: 3
