查看: 4760|回复: 7
[已解决] VBA怎样删除重复的圆?
发表于 2010-1-23 17:30:13 | 显示全部楼层 |阅读模式 来自: 中国江苏无锡
弱弱的问一下大家,CAD中怎样用VBA标记出有重复的圆,并提示删掉?我现在用选择集选择了所有的圆,想用圆心相等来判断(还得半径相等),可是圆心不让比较,请大家帮忙,最好给出代码,谢谢啦!!
发表于 2010-1-23 21:19:09 | 显示全部楼层 来自: 中国浙江宁波
& n/ Z/ d6 |" Y. l/ x7 y; J# C: p/ v4 f$ H% e  X- j9 z
circle对象的center属性返回的是一维三元素数组,0代表圆心的x坐标,1代表圆心的y坐标,2代表圆心的z坐标,可以分别通过比较x、y、z坐标判断圆心是否相同,注意控制坐标值的对比位数;
& W2 S/ f; g& S4 f' ?+ u9 s8 Vcircle对象的center属性示例代码如下:* B  k6 `& E; c2 B# [' A) F% N7 c4 j+ C
Sub Example_Center()
: P/ y% E3 F2 S) wDim circObj As AcadCircle    & E2 u% `5 N  p; U9 G7 ~
Dim currCenterPt(0 To 2) As Double
. Y. M5 y/ h# J, P/ \) K9 `Dim newCenterPt(0 To 2) As Double
) ^. h. y/ G2 w: LDim radius As Double
  M) E: ^; Z, z. q) _2 d$ Q' Define the initial center point and radius for the circle
4 x# w( E) s( R5 hcurrCenterPt(0) = 20: currCenterPt(1) = 30: currCenterPt(2) = 0    # t% h& V# H% z: E
radius = 3        - W: z4 z% n$ X" {
' Create the circle in model space    : x: ], F* h* B( G7 Q0 }
Set circObj = ThisDrawing.ModelSpace.AddCircle(currCenterPt, radius)
( S1 h( z: Q7 u- J0 s& KZoomAll
2 ?/ {. n- @# Y, p. X7 WMsgBox "The center point of the circle is " & currCenterPt(0) & ", " & currCenterPt(1) & ", " & currCenterPt(2),vbInformation, "Center Example"    # y: p4 j0 b! Q; \. J. \. E
' Change the center point of the circle    * M) W& I/ j, l& N+ N( m5 M! H
newCenterPt(0) = 25: newCenterPt(1) = 25: newCenterPt(2) = 0
& m0 u# L4 g$ z, Y0 xcircObj.center = newCenterPt      K+ D+ z# c, d" j6 a- ~
circObj.Update
8 c0 `# S& {3 O: _' Query the results of the new center position    ; r6 Y. e$ }' b4 t, }: V6 c' ?( l
' Notice the output from the center property is a variant    ' F. m7 N: {2 ~. ]' W
Dim centerPoint As Variant    / d0 V+ |! B! {5 Q, l3 q
centerPoint = circObj.center      S$ _# n( e1 C2 P) V& d
MsgBox "The center point of the circle is " & centerPoint(0) & ", " & centerPoint(1) & ", " & centerPoint(2),vbInformation, "Center Example"
8 y8 m& d. j4 B7 lEnd Sub
woaishuijia + 5 应助
发表于 2010-1-23 22:03:55 | 显示全部楼层 来自: 中国辽宁营口
圆心(点)是数组,得分别比较三个坐标才行.
  1. ) F3 [! X7 J4 A: P: U
  2.     Dim SS As AcadSelectionSet, FT(0) As Integer, FD(0) As Variant, C1 As AcadCircle, C2 As AcadCircle, I As Long, J As Long0 x, Q. O; \# i
  3.     FT(0) = 0: FD(0) = "Circle", [; w. U" Z- ~/ B9 J6 t: P; I* l( |
  4.     Set SS = ThisDrawing.SelectionSets.Add("SS")5 @1 W; O4 w$ ~* \
  5.     SS.Select acSelectionSetAll, , , FT, FD" h7 @9 n( a! S1 d* g( o
  6.     If SS.Count > 1 Then4 V% v: k7 e* K2 _9 Y1 F9 D
  7.         For I = SS.Count - 1 To 1 Step -1$ L0 U8 r: |1 x  b8 T  k
  8.             Set C1 = SS.Item(I)
    8 P0 b" a: s8 e7 p. L  Q0 z& }/ k( J
  9.             For J = I - 1 To 0 Step -1
    6 z6 d3 [! O6 P4 c5 r) S1 ?: Y) d
  10.                 Set C2 = SS.Item(J)
    - d' q0 u% k3 V$ G  S( W
  11.                 If C1.Center(0) = C2.Center(0) And C1.Center(1) = C2.Center(1) And C1.Center(2) = C2.Center(2) And C1.Radius = C2.Radius Then8 A, V2 J7 x" @2 g) d1 F5 W- s
  12.                     C1.Delete
    ) ]0 c: j* E3 G5 w5 Y
  13.                     Exit For, u: |5 {* U7 }( L& L0 ^" V
  14.                 End If
    : Z% [" f! K% [. f
  15.             Next
    4 X3 a! B/ [0 D7 z8 k  K- ?
  16.         Next
    / N: q4 H' l1 ]3 M) e% C
  17.     End If8 K1 b# z! S: r
  18.     SS.Delete, ]) H8 [1 }. Q( a: k: w
复制代码
 楼主| 发表于 2010-1-25 23:17:13 | 显示全部楼层 来自: 中国江苏无锡
豁然开朗,我知道我错哪了,谢谢大家了!
发表于 2010-7-13 14:52:44 | 显示全部楼层 来自: 中国江苏无锡
我也在学习中,谢谢楼主
发表于 2010-10-4 20:33:16 | 显示全部楼层 来自: 中国广东深圳
如果好了的话楼主将怎样删除线的命令一起研发下吧
发表于 2010-10-4 22:08:42 | 显示全部楼层 来自: 中国江苏无锡
如果好了的话楼主将怎样删除线的命令一起研发下吧- X) |: b8 Y# L; u) m
3duser 发表于 2010-10-4 20:33 http://www.3dportal.cn/discuz/images/common/back.gif
0 g3 i/ q0 H+ _* a安装ET工具,输入overkill即可
发表于 2010-10-9 16:15:38 | 显示全部楼层 来自: 中国上海
